DTC U1001-U1254 Loss of Communications
Powertrain Control Module (PCM) U1016
Vehicle not starting an running ?
Do you know anything about GM class 2 serial data network .
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring (Node Alive messages). A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that module's Node Alive message. Each module on the class 2 serial data circuit which is powered and performing functions that require detection of a communications malfunction is required to send a Node Alive message every 2 seconds. When no message is detected from a learned identification number for 10 seconds, a DTC U1016
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that can not communicate.
Control Module
ID Number
016
Electronic Brake Control Module (EBCM)
040
Body Control Module (BCM)
064
Sensing and Diagnostic Module (SDM)
088
Instrument Panel Cluster (IPC)
096
Do you know how to do a loaded circuit test for the power an ground circuits for that module ?
U1016 Loss of Communications with PCM U1055 Loss of Serial Communications for Class 2 Devices
This is going to require special testing with a GM scanner, it is not a do it yourself repair. My guess is this you have a defective instrument cluster display
There is a Pontiac Technical Service Bulletin addressing your exact issue, right down the the same exact codes you are getting. Here is the information I gathered and I will place a link to the page where I found it. You will need to scroll down the list of TSBs to find your specific one. Apparently this is a problem for the Grand Prix.
Here is the basic data:
TSB Number:
0308116001
NHTSA Number:
10002880
TSB Date:
February 1, 2004
Date Added to File:
September 30, 2003
Failing Component:
Electrical System
Summary:
Diagnostic trouble code (DTC) U1000, U1016, U1064, U1096 or U1305 set in error. This bulletin replaces previous bulletin dated 06/01/2003.
Here is the Link:
