Question about Amana DLE330RAW Electric Dryer
Timer dial does not mover - Amana DLE330RAW Electric Dryer
  • brennan441 Jul 13, 2009
    I meant it doesn't move, the dryer comes on, drys, but does not turn off. You have to manually move the dial. How can I refuse to select any position?
  • 132 Answers
If you mean it refuse to select any position so i think it need to dismantling slowly and mantling again only only<
thanks
Posted on Jul 13, 2009
Kenmore elite dryer # 110.70982990 timer problem
The timer is bad. Specifically the timer advance motor is going bad. It is a little electric motor located on the back of the timer. It movers the knob forward automatically as the dryer runs cutting down on time remaining. You usually have to buy the entire timer, you cant replace just that part.
May 17, 2016 | Kenmore Dryers
After installing new timer, timer has power but lights not coming on
10-17-12
Check light bulb?
Have you programmed the timer?
Did you clear timer with reset before programming?
Are there conflicts and overlap in timer programming?
Did you mover slide switch to timer?
Which timer do you have?
Copy following link for correct wiring.
http://waterheatertimer.org/How-to-wire-timers.html
If you have analog timer:
http://waterheatertimer.org/How-to-set-timers.html
Add a comment with more information.
Oct 16, 2012 | Coleman Cable Woods 59018 InWall 7Day...
Lights not coming non after install
10-17-12
Not sure which timer you have.
Check light bulb?
Oct 16, 2012 | Hardware & Accessories
The freeze protection just quit qorking when it dropped to freezing i turned the dial to 45 and it still will not come on has been working non stop for about 4 days. i am in the dfw area
You can replaced the freeze control without buying entire timer:
Google: "Intermatic thermostat freeze control" to see cross selection of choices.
For example Smarthome sells PF1103 for $80: works for 120 or 240
http://www.smarthome.com/42699/Intermatic-PF1103M-120-240V-Freeze-Protection-Control-Timer-Mechanism/p.aspx
To prevent freezing right now, the pump should run full time, so pull trippers off the timer dial, and mover override lever to ON position. This will keep the pump running.
When the temperature rises, put trippers back on dial, and then order new part.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 06, 2011 | Intermatic Timer PF1202T Multi Circuit...
I have a G.E. 24 hour timer GE5101N . It says to set time when you want the lights to go on. How will it know when to shut the lights off?
See GE timers on following link to identify timer:
Link has instructions plus large image you can see segments lifted up and pushed down
http://waterheatertimer.org/GE-timers-and-manuals.html#GE510N
Timer knows when to turn lights on-off because segments are lifted up or pushed down.
Push/lift a few segments.
Turn lamp ON
Plug lamp into timer.
Mover switch to Timer ON
Plug timer into outlet.
Manually rotate dial clockwise to see lights turn on-off.
This will show if segments should be up or down.
Set segments for ON OFF times.
Rotate dial until current time lines up with pointer.
Jan 26, 2011 | General Electric Hardware & Accessories
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
I need instructions on how to use the GE Ge 15107 24Hour Yard Stake Timer
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15107-Manual-eng-spn.pdf
Above is link to GE 15107 manual
This is a 15amp timer that can handle up to 1440 watts
How to set timer
Rotate center dial to set current time
Line up current time with triangle on inner part of dial
The timer dial shows nighttime hours on dark part of dial, daytime hours show on light part of dial
The timer dial rotates like a clock after it's plugged in
The outside edge of timer dial has 48 segments
Lift up these segments for times you want timer OFF
Segments down for timer ON
5c24d6c.jpgSegments up, timer OFF. Segments down, timer ON.
Segments in photo are on the GE 15207 timer
Oct 21, 2010 | GE 15107 24Hour Yard Stake Timer
When we put the dials all the way up the freezer freezes up and the fridge gets warm We just moved it a week ago
Most likely the vibration of the move has caused:
- your defroster timer has failed or is stuck
- your defroster heater element has failed.
On most fridges, there is a little timer knob, which is the defroster timer, located at the bottom front behind the front kick panel.
If you rotate the timer by hand, you should hear a click. This should turn off the compressor and turn on the defroster heater. The heater should make some hissing/scorching sounds, plus the sound of water draining out.
The timer, if functional, should then turn the defroster off, and turn the fridge back on after a half-hour or so.
Since this part is typically on the bottom of the unit, maybe the part or it's wiring got broken by the mover with the fridge dolly. Or else the vibration of the move broke the heater element or caused a wire connection to come loose.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana DLE330RAW Electric Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
