Question about Nintendo GameShark Pro for 64
Gameshark 3.2 trouble
Gameshark 3.2 displays 8 and has a blank screen. Please help
  • nintendoboyn Jul 15, 2009
    thanks. but i did one better, i unsrewed the casing and cleaned the contacts with rubbing alcohol and then waited for it to try, I did some more research on the net, apparently if i use the game 007 Golden Eye it has a default code to unlock it. However, when i used the game it still displays an 8.
    There was nothing at all on the circuit board to cause such a problem. Infact this is strange everything seemed to be welded correctly. I don't know about it except is there a printed schematic a legal copy of it? The only thing that i could think of is that the software is corrupted somehow. lol. I am not to sure how a virus is formed on a device that isn't connected online.
    P.S. Thanks again for the advice, I'll keep digging.
  • 4 Answers
If this is the cartridge type.. try cleaning the part where you insert it into the system, with a cue tip and rubbing alcohol. It's possible that it may have gunk in it. Let it dry before you put in the game.
This may help
Posted on Jul 13, 2009
If it did that after you entered a keycode to a game that wasn't inserted. it's just locked up.insert the game that you entered the keycode to and it should work.
Posted on Oct 26, 2009
Nothing happens except the number 8 shows up but nothing else happens with the gameshark 2.0
http://www.atariage.com/forums/topic/132541-some-help-with-my-new-gameshark-pro-3-3-for-n64/ Check this site... Check the pins in the cartridge and the game shark... Try with different games... Make sure its clean and making all connections. :) hope it helps.
Feb 09, 2013 | Video Game Consoles & Games
Gameshark n64 v3.0 will not start up
if you have any other games like mario 64 or james bond use those
Dec 16, 2012 | Nintendo GameShark Pro for 64
The game will start and the screen gets past the "gameboy" logo with the little jingle, but after that it just stays at a white screen. without the gameshark, the game works fine. i dont know if...
The connectos on either side of the cart is dirty, Here is a simple solution. Take out your gameshark and switch it to off. Blow in You game boy cartridge slot and your game shark. Put your gameshark in, then take it out . Repeat this process a couple times.
Thank you for your time, Good luck and I hope this works
Jun 08, 2011 | Video Game Consoles & Games
Why i have cheats for gameshark?
ok heres what you do you need to open the panel between the start and reset button pry out the jumper pack thats in there then you need to buy a extension pack and put that in then u can play
Nov 25, 2009 | Nintendo 64 Console
It says 8 and the screen is black
put in one of the good games and go to keycodes and selct zelda. Turn off the n64 and put the game you want to use in the gameshark then turn it on and it should work
Aug 28, 2009 | Nintendo GameShark Pro for 64
GOD GARNED N64 GAMESHARK!
The original GameShark for the N64 only works on certain games. During the N64 era, game creators would often include code on the game itself that prevented the use of a GameShark. It is possible that you can find a newer version of the GameShark that would work with this so called "blocked" games, but it might be difficult.
I'm assuming that this is the GameShark Pro for the N64. If so, the button is used to find and create your own cheats, such as infinite life, infinite ammo, etc...
To use this feature, start the game, say a first person shooter, and load into a level and when you are ready to begin playing, press the button. The GameShark screen will show up and you can say "search for code" or "search for changes" something like that and the game shark will run a diagnostic that it shows on the screen. A number will appear noting the number of lines of code executed since the game loaded. When it is finished, press the button again and it will return you to the game exactly as you left it. If you are trying to get infinite ammo, simply shoot once and press the gameshark button again to search for codes again. When it is finished, the number it shows will be much smaller, since much less lines of code have executed since the last run. Press the gameshark button again to return to the game and continue the process until you have only a few, say 5 or less, or even just one code left on the gameshark diagnostic. This code will be the one that dictates the amount of ammo that you have. By altering this code with the gameshark, you can either start with an extremely high amount of ammo, or have infinite ammo entirely. The key to this strategy is to do as little as possible between code searches so that you can quickly narrow down on the code that you trying to alter. Hope this helps.
Aug 05, 2009 | Nintendo Video Game Consoles & Games
I turn it on, it shows the gameboy, nintendo sign, and goes blank
Gameshark and other cheat codes have a tendency to mess up or freeze the games. This is usual.
Apr 07, 2009 | GameShark SP for Game Boy Advance
My n64 gameshark won't turn on
my gameshark wont work i have sm64 and alot more games i turn it on and it just sits there an says 8
Aug 25, 2008 | Televison & Video
IM CONFUSED!
Mine does that sometimes.I got it on Ebay for just a few dollars. I think it does that when there isn't a good connection between the game/gameshark/N64. I always use the "hot breath" method - breathe on the slots of both the gameshark and game, as if you were trying to warm up your hands in wintertime, or fog up a mirror. It might take a couple of tries, but it usually works.
If that fails, try cleaning the slots of the gameshark and game with a Q-tip - there can be a lot of corrosion on the copper connections - but don't use any kind of cleaning agent, just rub at it. The Q-tip will probably end up being gray or black. Then try it again.
Jul 10, 2008 | Nintendo 64 Console
Nintendo GameShark Pro for  64  Logo
754 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
