Question about Microsoft Excel for PC
VLookup? Excel assistance please. I have a spreadsheet with column A has the person's name 3 times each. Column B has 3 different types of exercises and column C has the reps. I have a spreadsheet with a drop down list to pull the name of the individual that you are looking for but below it, the vlookup to pull the person's stats only pulls stats from the first row since the name is show 3 times. How do I adjust it if I need it to pull the stats for all 3 excercises?
  • 21 Answers
I would create more columns as such
|__A__|______B____|___C___|_____D____|___E___|_____F____|___G__|
NAME EXERCISE1 REPS1 EXERCISE2 REPS2 EXERCISE3 REPS3
That way you can use VLOOKUP and make sure you include the appropriate column in the VLOOKUP(NameOfPerson,A:G,3) this will get you the reps for exercise1
VLOOKUP(NameOfPerson,A:G,5) this will get you the reps for exercise2
etc.
Doing it this way will also make it easier to add more exercises. It will be worth the time of converting what you already have. But if you have hundreds of thousands of people then I might be able to write a quick Visual Basic program to convert what you have.
Posted on Jul 17, 2009
    President:
  • 627 Answers
Select all columns
clik on data click filter select autofilter
Posted on Jul 13, 2009
Vlookup for duplicate cell values to display both names in separate cells
Check your formulae for a small error. Use F1 to guide you.
Jul 14, 2017 | The Computers & Internet
Sum numbers in a column down until you come to a blank, then start again
Sounds like your issue can be solved readily with a pivot table.
If you give the columns of names a title like "NAME" and the number columns a name like "VALUE". All other columns should contain a unique name.
Then select the entire table, including the labels at the top ensuring that the range extends entirely over the column you need to sum the values of.
In Excel 2013, choose the INSERT menu and select the PIVOT TABLE command.
Insert the Pivot table into a new worksheet.
A new sheet will open with a strange-looking control panel on the right of the window.
Make sure that the box for NAME and VALUE (only) are checked
You will notice that Excel assumes that you want the SUM of the values for each NAME summed. The results are in the leftmost area of the worksheet.
If this works for you, please vote my answer as "helpful".
Sep 03, 2014 | Microsoft Excel for PC
What is vlook up & what is hlook up?
The VLOOKUP and HLOOKUP functions contain an argument called range_lookup that allows you to find an exact match to your lookup value without sorting the lookup table
I have posted below link to know more .Please have a look..
http://www.howtodothings.com/computers-internet/how-to-use-the-vlookup-and-hlookup-functions-in-microsoft-excel
http://support.microsoft.com/kb/181213
http://office.microsoft.com/en-us/excel-help/vlookup-HP005209335.aspx
http://www.timeatlas.com/5_minute_tips/general/learning_vlookup_in_excel
Please rate & vote if you like soution..
Thanks
Sandeep
Mar 14, 2011 | Microsoft Excel for PC
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
Feb 11, 2009 | Microsoft Excel for PC
What are uses of vlookup n hlookup?
An implementation of the vlookup in Excel could be:
You have an Excel table with student names and their grades.
You wish that you could somewhere in the sheet type a student name, and immediately retrieve his grade (based on the data in the table).
To achieve this, you can use "Vlookup": the function will look for the student’s name in the first column in the table, and will retrieve the information that is next to his name in the second column (which is his grade).
Hlookup is the same excpet it is for data arranged by rows instead of columns.
Dec 29, 2008 | Microsoft Office Home and Student 2007...
Need to use the VLOOKUP formula for more then one column
You probably need to organise your pricelist sheet so that you only have 2 columns, product and price. If this doesn't fix you, please provide the syntax of your vlookup code.
Dec 10, 2008 | Microsoft Excel for PC
HELP with macro config
Hi Hss Holdings,
The easiest way to do this is to use a formula called vlookup. You need to have the raw data some where in the workbook, but it can be a separate sheet. Put all the raw data in a table, make sure the account number is on the furthest left column, then start entering the formulas
vlookup(value_to_find, table_to_check, column_index_number, range_lookup(true/false))
value_to_find = the value you want to find on the left most column of the table
table_to_check = the table you want to find the data from
column_index_number = the column number of the data field you want to return into this cell, 1 = the left most column.
range_lookup = false for an exact match, true for the nearest match
Say the table is on sheet2 between A1 and E300
B15 is whatever you type, so no formula needed here
B12 =VLOOKUP(C1,Sheet2!A1:E300,2,FALSE)
G12 = B12 =VLOOKUP(C1,Sheet2!A1:E300,3,FALSE)
etc
Jul 12, 2008 | Excel (SS8SATAS5128400R)
Lookup,s
If you can move your name column (C) to the first column, you could leverage the VLOOKUP formula pretty easily.
To do this, do the following:
1) Move the C Column to be the A Column, shifting all other columns to the right.
2) (optional) Insert a new row at the top of the sheet (to hold the formula & seach value)
3) Use A1 as your search field.
4) In A2, enter the following formula:
=VLOOKUP($A$1,$A$2:$C$6,3,)
Describing above parameters, in the formula:
$A$1 -> the search field (name your looking for).
$A$2:$C$6 -> The table/grid you wish to search and return values from. The left most column (A) must contain the values to be searched.
3 -> is the column number (A=1,B=2,C=3, etc) within the table/grid to return.
If you cannot make the name column your first (A) column, there are more complex ways to do this. For instance, create a new sheet which redisplays the info in the structure easier for this method, and perform the VLOOKUP on that data. Other options might exist in creating a complex formula that would get you what you want.
Also, if you can sort column A (names) it would find results faster, if your data set is large.
Feb 03, 2008 | Microsoft Excel for PC
Ms excel
Vlookup: =VLOOKUP(A1,A1:C10,3,FALSE) 1. Lookup_value - A1 the value you want to search. 2. Table_Array - A1:C10 You will only search the lookup_value in the left column which is A1:A10 in this example. 3. Col_Index_Number - If you find a matching value give me column 3. Since A1=A1 it will give me C1. In this example 1 is A, 2 is B and 3 is C. 4. Range_lookup - I always choose false which is exact match. True will give you approximate match and its not always correct. Vlookup is used when you have a list of values and you want additional values that exist in other fields. You will get those values only for the fields that you search for. In your example you can get the address by running vlookup at the names, it is also good way to search duplicates. Q2 is very simple, on field D1 just type: =A1 & " " & B1 & " " & C1 Just drag it or double click on the drag square Let me know if you have any other questions Daniel
Sep 24, 2007 | Microsoft Office Standard for PC
Function
VLOOKUP is to Searches for a value in the leftmost column of a table, and then returns a value in the same row from a column you specify in the table. Use VLOOKUP instead of HLOOKUP when your comparison values are located in a column to the left of the data you want to find. The V in VLOOKUP stands for "Vertical." Syntax VLOOKUP(lookup_value,table_array,col_index_num,range_lookup) Lookup_value is the value to be found in the first column of the array. Lookup_value can be a value, a reference, or a text string. Table_array is the table of information in which data is looked up. Use a reference to a range or a range name, such as Database or List. If range_lookup is TRUE, the values in the first column of table_array must be placed in ascending order: ..., -2, -1, 0, 1, 2, ..., A-Z, FALSE, TRUE; otherwise VLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted. You can put the values in ascending order by choosing the Sort command from the Data menu and selecting Ascending. The values in the first column of table_array can be text, numbers, or logical values. Uppercase and lowercase text are equivalent. Col_index_num is the column number in table_array from which the matching value must be returned. A col_index_num of 1 returns the value in the first column in table_array; a col_index_num of 2 returns the value in the second column in table_array, and so on. If col_index_num is less than 1, VLOOKUP returns the #VALUE! error value; if col_index_num is greater than the number of columns in table_array, VLOOKUP returns the #REF! error value. Range_lookup is a logical value that specifies whether you want VLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, VLOOKUP will find an exact match. If one is not found, the error value #N/A is returned. Remarks If VLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than or equal to lookup_value. If lookup_value is smaller than the smallest value in the first column of table_array, VLOOKUP returns the #N/A error value. If VLOOKUP can't find lookup_value, and range_lookup is FALSE, VLOOKUP returns the #N/A value.
Aug 30, 2007 | Microsoft Office Standard for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
134 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
