Question about Primera Technology Bravo 2 Disc Publisher-CDR MAC (BRAVO2CDRMAC) Burner
BRAVO PRIMERA 11 ERROR CD PUBLISHER
I HAVE MY BRAVO PRINTER 11 WH I SWITCH ON I GET AN ERROR IN BLUE RIGHT SIDE LIGHT IS BLINKING CONTINUASILY SO CAN YOU HELP ME TO KNOW WHAT IS THE REAL CAOSSES OF THIS ERROR FROM DENIS,
PRINTER IS BRAVO PRIMERA FOR DISC PUBLISHER
    Problem Solver:
  • 15 Answers
The Publisher has a cartridge problem. Check to make certain that the cartridges are installed correctly and that the bar code labels on the underside of the cartridge are not damaged.
Posted on Sep 07, 2009
It says you must select robot and its recorder to write discs
Did you install the software? If I remember rightly the Mac version requires Discribe software. Let me know and we'll see if we can narrow it down.
Jul 23, 2009 | Primera Technology Bravo SE Printer
Bravo stops printing after each disc with blinking light.
Which light. If the one on the left, I think that the LEADS (red/clear) that check the Ink cart are dirty. Clean with qtip. I usually take one from my mouth...then dry end. (I know sick).
Rich
Jul 18, 2009 | Primera Technology Bravo (Refurbished)...
Won't print
I think you need to check it with warranty if it comes with it. Because if it has sometime left with warranty try using that. I do believe that if its problem with parts than its different issue. Check if there is an error showed in the PC when you give orint command does it show any dialogue box with error and what is it? Try uninstalling and using its software remedies which comes with the CD.
Mar 12, 2009 | Primera Technology Bravo II AutoPrinter...
Hiya how do i check the inks on my bravo 2 primera
Go into your printer driver; ie. control panel -> printers and right click the CD/DVD printer. Press "Printing Preferences" near the bottom of the Properties window. Click on "Clean/Change cartrdiges & check Ink" and select properties.
Mar 05, 2009 | Primera Technology Bravo II AutoPrinter...
Primera Bravo CD/DVD printer -- prints blank
Let the printer repair itself. Got to start menu select the printer then select properties. Go to maintenance menu try all the basic testing. If it still didn't work out, delete the previous driver and install it again, then restart and try printing again.
Dec 14, 2008 | Primera Technology BRAVO AUTOPRINTER (Open...
The disc arm for the bravo disc publisher primera is telling me that the disc was not picked up, and to press the left button on the machine to try again. I have done this plus I have turned off both my...
hi,
i think you already need to clean your equipment.
this is part of the manual of your equipment and follow their tips to prevent damage.
go to this link: http://www.primera.com/manuals.html
to download the files.
Section 5: Maintenance and Troubleshooting
A. INTERPRETING THE PUBLISHER’S INDICATOR LIGHTS
The Power/Ink button can tell you what is happening inside
the Publisher. Please refer to the following:
Power/Ink Button Publisher
Fast Flashing The Publisher is initializing.You will see this
pattern when the Publisher is first turned on.
Wait until the lights stop blinking before
opening software or starting jobs.
Slow Flashing The cover is open and the ink cartridge carrier
is in change position. Insert a new cartridge
and close the cover. (The slow flashing light
can also indicate an out of media condition,
a robotic error or a picking problem. However,
these conditions are always paired with a error
message on screen.)
B. CLEANING THE PUBLISHER
NOTE: Do NOT attempt to oil or grease the Publisher's Robotic Arm shaft
or other components. You will likely cause more harm than good!
Any moving parts are designed to operate for the life of the machine
with no additional lubrication required.
Use a clean, lint-free rag with a small amount of ammonia
window cleaner to clean the Publisher's outside case and
trays. This type of cleaner is very effective on inks that may
accumulate on the printer tray. Stronger cleaning solutions are
NOT recommended because they may damage the paint and
plastic materials from which the parts are manufactured.
Always disconnect your Publisher's power cords before
cleaning. Resume operation only after the surfaces are
completely dry.
C. PERFORMING A ROBOTIC SELF-TEST
To ensure that everything is working properly, a Self-Test
feature is built in to your Publisher. In this mode, the Robotic
Disc Transporter will go through the motions of picking and
placing a disc to ensure proper working order. This test may be
performed without connecting the Publisher to the PC.
Perform the test by doing the following steps:
• Load some discs into the Input Bin.
• Open the cover.
• Press and hold the power button for five seconds. The test
will start.
• To stop the test, close the cover and press the power
button.
D. CLEANING THE INK CARTRIDGE
It may be necessary to clean the ink cartridge nozzles if you
notice reduced print quality, or if you suspect an cartridge nozzle
has become slightly dried out or clogged. If you are having
print quality problems, follow the steps below:
1. Remove the print cartridge.
2. Moisten a lint-free cloth with water.
3. Hold the cloth against the
nozzles for three seconds.
This will “wick” some
additional ink onto the damp
cloth.
4. Wipe in one direction only.
5. Repeat the process
E. TECHNICAL SUPPORT
If you have difficulties in operating your Publisher, the
procedures in this manual and the software User's Guide
should, in most cases, solve the problem. If you still have
difficulty, contact the technical support number listed on the
insert included in the supply pack that came with your
Publisher.
Source Location
Primera Knowledge Base www.primera.com/knowledgebase.html
PTPublisher Software Help files Open the software. Click on the ? icon in the
upper right corner of any screen.
SureThing Software Help files Open the software. Click on the Help
Menu - Contents
Email Support www.primera.com/contact_tech_support.cfm
Chat Support www.primera.com/knowledgebase.html
Phone Support 763-475-6669 (Mon - Fri 8 a.m. - 7 p.m. CST)
Nov 22, 2008 | Bravo Computers & Internet
Primera Bravo Pro
Pioneer 115's require a special firmware to allow the drive trays to eject far enough so that the robot can drop the discs into the tray cleanly. The firmware for the 115 can be found at http://www.primera.com/downloads/support/DriveFirmware/DriveFirmware.html. Hopefully this should fix your problem.
Aug 04, 2008 | Primera Technology Primera BravoPro...
I can,t print
this usually indicates there is a problem with the cartridge, check the bottom of each cartridge and see if the colour barcodes are intact and ensure you are not trying to start the machine with the lid up as too much light coming in will also cause the problem when reading the coloured barcodes on the bottom of each cartridge
Apr 16, 2008 | Primera Technology BRAVO AUTOPRINTER (Open...
Computers & Internet Logo
338 people viewed this question
Top Primera Technology Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Terry Hair
Are you a Primera Technology Computer and Internet Expert? Answer questions, earn points and help others
