Question about Waring WCT704 4-Slice Toaster
Waring toaster WCT 805 heating element problem
Falling Down
  • 67 Answers
SOURCE: Toast Master Toaster TP409
if you mean the toast itself doesn't toast on one side, check that both heating elements have about the same resistance value. One could be twice as conductive as the other and not heat as much as the other side.
If you mean the other two slots don't toast, the problem could be in the switch or in the elements themselves. check carefully the continuity of the toaster across the (unplugged) ac power connector while you push the toaster load handle down on each side. If the resistance is significantly larger on the problem side, the problem is either the switch or the elements. The problem is usually with the switch becoming corroded or oxidized. The switch is supposed to be self-cleaning, that is, it wipes itself as contact is made to help remove buildup. Sandpaper both contacts until they shine copper colored. Otherwise look at the elements while toasting. dark areas mean lower wattage is being dissipated and the element may be bad near a dark spot.
Posted on Nov 30, 2007
juliant61
SOURCE: Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Posted on Nov 30, 2008
cactus bob
  • 267 Answers
SOURCE: "Outside" heating elements don't heat up. Can I find replacements
its not the elements . its the control board . and you cannot buy a control board , but it can be fixed there is a small relay on the board that needs to resoldered to the printed curcit board . its a pain the the rear-end to get to it , fix it and get back in there and all back together but it can be done ( about 3 hours total ) , if your like me and never say never ......... good luck
Posted on Feb 19, 2009
SOURCE: Heating element broken
Now we are using kanthol heating element,,,,,,,, capacity 200A,,,,
its frequently cutoff during process whats the reason,,,,,,,,
Posted on Dec 23, 2009
  • 248 Answers
SOURCE: do you work on toasters? after cleaning toaster,
wiring may have gotten wet while cleaning try using hair dryer,blow through all the vent holes for a few minutes
Posted on Oct 07, 2010
Waring pro toaster oven: the toaster part spring would not stay down. How to repair?
Most of the time this problem is caused by a build-up of toast crumbs in the latch mechanism. Unplug the toaster oven and follow the instruction manual directions for cleaning the toaster section. Try cycling the toaster lever up and down a few times, then clean out the crumb tray again. If that doesn't solve the problem, you'll have to look for an access to the latch mechanism to clean it out and perhaps gently straighten the latch hook if needed. Note: these are generic directions for all such toasters. I can't be more specific without knowing which model in the Waring Pro line you have.
Jul 02, 2017 | Waring Toaster Ovens
Heating element on toaster oven have mercury in them
No they don't. If they did it would be online and they would never get through inspection anyway. Mercury is expensive, but you do find mercury in all florescent tubes and compact florescent lamps in very small quantities. Toaster oven elements are radiant and have a metal element inside a ceramic glass tube.
https://www.google.ca/search?q=Heating+element+on+toaster+oven+have+mercury+in+them&sourceid=ie7&rls=com.microsoft:en-CA:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=bokqWOz-NoWN8Qe66IegDw
Heating element on toaster oven have mercury in them Google Search
Nov 15, 2016 | Toaster Ovens
3 of 8 elements are not working. will new ones fix this or should i order other parts just in case?
I would buy a new toaster myself . fixing the old one will not last as long as you hope as the old parts will fail as they will be weak compared to the new wires
Jul 27, 2015 | Waring Wct805b 4 Slot 208v Heavy Duty...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Toaster no longer heats. Can I purchase the heating element and install myself?
mcdevito75 here, Chances are the heating elements are soldered in on the toaster and may take special tools to fix, if the heating elements sre burned out, maybe better to get another toaster.
Jun 19, 2010 | Dualit Vario 2 Slices Toaster
How do a toaster heatingelement work
The toaster heating element converts electricity in to heat energy through the process of Joule heating effect. the electric current flowing through the element encounters electric resistance, resulting in heating of the element.
Sep 13, 2009 | Kitchen Appliances - Others
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
One side not working
Sounds like the element has failed. Not much you can do as even though they cost more than a 2 slice, parts availability is slim and none.
Jan 28, 2009 | Waring WCT810 4-Slice Toaster
Dec 20, 2008 | Waring WCT704 4-Slice Toaster
Waring WCT704 4-Slice Toaster Logo
153 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
