Question about Sanyo EM-Z2100GS Microwave Oven
What is the ceramic fuse to the mains power supply
Sanyo 900 Microwave - What is the ceramic fuse to the mains power supply.
Many thanks
  • 132 Answers
It is a fuse connected to the start of path of electricity to the power supply inside the m/c so if is burned it will cut the electricity from connectedto m/c > it will cause m/c to stop working >
it will be easy to see it from its material it is from ceramic>
thanks
Posted on Jul 13, 2009
Can a microwave be repaired?
Yes it is repairable, but if you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. If light and turntable works than low voltage circuit (220V or 110V) works well. In this case the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or in the main board. If light and turntable does not work than fault could be in power supply elements like: power supply cord, transformer, power board, fuse (glass or ceramic, ussualy 8A, 10A or 12A) on power board.
Dado
Oct 24, 2015 | Kenmore Microwave Ovens
I replaced clock panel turn power on nothing is there a code
If no display---you may have a bad fuse. It should be located behind the control panel. The fuse will look like the old auto glass fuses about 1/4 diameter and 1 1/4 inch long but made out of a ceramic material you can't see through. Color could be white--brown or a gray color. Amp size will be stamped on the end usually 15 or 20 amps.
May 12, 2015 | Kenmore 4888 Elite 30" Built-In Microwave...
No power, even when plugged in to a live outlet.
The main fuse in the microwave oven has blown, the cause is usually a defective door switch.
Feb 09, 2011 | Sanyo EMG5595S 900 Watts Microwave Oven
I was warming a cup of coffee in a ceramic cup. The microwave ran for 2 sec. and then totally shut off. nothing works. we checked the outlet, the circuit breaker and everything has power to it
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 02, 2011 | LG Microwave Ovens
No Power
Hope this helps.
Dec 30, 2010 | Sanyo EM-S5002W Microwave Oven
I had a power surge in the house and now my GE sensor Microvawe is stone dead. Any ideas.
It is possible the main fiuse in the Microwave has blown. Sometimes this is a special ceramic fuse and costs around $30. But to get to the fuse you have to remove the outer cover of the microwave( unplug it first) It is usually located on Top left side of the unit. Once replaced it should return to service.
Please rate our help++++Thanks for using FIXYA
Oct 12, 2009 | GE JVM1630 Microwave Oven
Daewoo Microwave KOG 867 T9-DEAD??
There could be a main fuse inside the unit. Mine has one that is ceramic, sort of like the old glass car fuses but ceramic instead of glass. Digi-Key has all kinds of fuses, www.digikey.com.
Aug 03, 2009 | Daewoo KOG-867T Microwave Oven
Plug it in, does nothing. . .main fuse is fine
I had one that got zapped during a thunderstorm. Deep inside there was a ceramic fuse, looked like the old glass kind in cars except it was ceramic. Bought a replacement through Digi-key, it's worked fine ever since. Point is, there may be a separate 'main fuse' that you can't get to without opening it up.
Aug 03, 2009 | Panasonic NN-S634 1250 Watts Microwave...
Unit does not respond to anything-no power indication. It is 15 months old. any suggestions?
If there is no sign of power at all it may be that the fuse for the internal power supply has blown.
These are normally a special ceramic type and I have seen these simply give up when a microwave oven door is slammed shut a bit too hard. Recently happened to me.
The fuse should be visible as soon as you have removed the main casing. They are a special ceramic type. Normally if you look on the circuit board where they are mounted on you will see the rating for the correct fuse.
Try this first, If it fails again then something is drawing too much power and it should be further investigated by a service engineer.
Jul 04, 2009 | Kenmore 66029 Microwave Oven
Nothing working - just quit. Power source ok.
There are 3 fuses in that microwave. I had a similar issue. The one that I had to replace was the little ceramic fuse that is in line after the big fuse which is connected to the main line.
I couldn't find the ceramic fuse but I replaced it was a glass one about a year ago and it has been working since then. The fuse if located on the right front panel.
Dec 29, 2008 | Whirlpool MH3184XP Microwave Oven
Sanyo EM-Z2100GS Microwave Oven Logo
171 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
