Question about Wacom Cintiq 15X Graphic Tablet
I have a cintiq pl-550 but need usb cable for it, anyone no where get one (usb to 4pin Din)
Need a jvc gr-d71u driver for windows
Drivers are not neccessary when transferring VIDEO on "GR-D" camcorders. All you need is a firewire cable (4pin to 4pin) or (4pin to 6pin) depending on your computer. Once connected, you can use free DV EDITING SOFTWARE like, Windows Movie Maker or iMovie. USB ports on these cameras are reserved for transferring PICTURES ONLY
Jul 25, 2014 | JVC GR Video Cameras
WHICH FIREWIRE CABLE DO I GET FOR THE SONY DCR-TRV22E DV
you would need a ieee1394 4pin cable for the camcorder. of course the other end of the cable would depend on the computer's ieee1394 jack you'll be connecting the cable to. there are 2 types of ilink cables: 4pin-to-4pin or a 4pin-to-6pin (firewire 400) cable. latest mac computers uses a firewire 800 port so if your using one you may need a Moshi 800 to 400 firewire adapter if your having compatibility issues. see: http://store.apple.com/us/product/TW748LL/A for more information. hope this helps. thanks:)
May 29, 2010 | Sony Handycam DCR-TRV22 Mini DV Digital...
I have a Sony vaio computer for my system I purchased the Cintiq 12W tablet. When installing these Items together I came acrose the problem of not having a vga dvi outlet so I was informed that I would...
use a dvi - hdmi convert cable and connect via the dvi-d cable on the cintiq instead of the analogue. should have been your first move as it is alot cheaper than an external vga card
May 15, 2010 | Wacom (PTZ930AC) Graphic Tablet
Video to acer computer
If you want to copy analogue video to your computer to make a DVD video disk, then you need an analogue video capture device on your computer and of course a DVD burner.
There are USB analogue video capture devices on the Internet, and they cost under $100.00
Sep 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
I need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Do I need a 4pin-4pin DV cable or a 4pin - 6p -with Canon MV 850i
The camera has a 4-pin slot. If the slot on your computer has a slot the same size as your camera, it is 4-pin. If it is larger, it is a 6 pin slot.
Dec 31, 2008 | Canon ZR850 Mini DV Digital Camcorder
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Yes, it is in VCR Mode...
You need a 6 pin to 4 pin firewire cable, friend :) It should work with one of those.
Apr 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Wacom Cintiq 15X Graphic Tablet Logo
250 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
Ed Mac
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
