Question about Oster 12-Bottle Wine Cellar - Black
The temperature icon does not light up so you can read the numbers. I can't set it on the correct temperature. It keeps gong back to 70.
  • 736 Answers
When you are setting the temp the display shows the set value .. but when you release the buttons for a few seconds the display reverts back to the actual temp inside .. so if you set it at 55 deg F .. after a second or so it will jump back to 70 or whatever it happens to be at that time inside the cabnet .. eventually it should go down to your set point (several hours) .. but mine didnt .. it stayed at the room temp forever .. the fan was running but the solid state cooling device actually had no power (requires about 4 amps at 12 volts).... the problem was a blown fuse in the power supply inside the cabnet .. make sure the unit is not plugged in if you are going to take the back off the machine ... in my case all that was needed was to replace the primary side fuse (about 2 or 3 amps i think) there wasnt but there could have been other problems as well .. the power supply is what they call an "off line switcher" when it is plugged in it has dangerous voltage and current levels .. so again dont plug it in unless it is assembled in a safe manor ..
the same power supply might power the "back light" for your display ..
Posted on Jul 13, 2009
I inherited a Seiko Westminster chime clock. The time is perfect but the hourly chimes are 3 hours behind. How can I synchronize the two?
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Sep 21, 2015 | Seiko Mantel Clock
How do I adjust the chimes to the correct time?
May 12, 2014 | Home
How do I adjust the chimes with the correct time for a Campus Fugit clock?
May 12, 2014 | Home
How to Set time
Apr 27, 2014 | Home
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
Set chimes on qxh004blh seiko pendulum clock
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Feb 16, 2013 | Seiko Mantel Clock
My pendulum seiko clock needs to be reset, it doen't chime in the hours correctly
Jan 28, 2010 | Seiko Mantel Clock
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Oster 12-Bottle Wine Cellar - Black Logo
226 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
james laughton
james laughton
Are you an Oster Furniture Expert? Answer questions, earn points and help others
