Will not fill with water & reads error code ddr! What does that mean? why won't it fill with water?
Gallery Series Front loading washing machine What does error code: ddr mean?
  • Washing Mach... Master
  • 18,002 Answers
DDR means the door latch is loose or bad. There is a switch inside that needs to be checked or replaced.
Posted on Oct 16, 2015
I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
F2 code is water level to high
Washer Error Codes
Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
Asko Washer Error Codes
• F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
Sep 19, 2014 | Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire front load washer does not fill.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 04, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire gallery series front load washer that flashes an E10 error code. What is this for.
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing machine fills up and starts the wash cycle and then displays an F05 error.
F05 error code means heating circuit failure.The water temperature sensor is not working. It might be just disconnected or unplugged due to vibrations over time.Unplug the washer and open the housing. The sensor is located at the base of the wash tub in front of the heating element. It is square -shaped connected between the heating element terminals.Clean the terminal leads before reinserting.
If the sensor is well connected between the heating elements and the washer still not work, disconnect the heating elements and check the resistance. The resistance reading should be at around 9K ohms at room temperature, else replace.
Aug 06, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Error messages
what are other codes? i believe this could be a cold water issue. check your screens at the fill hoses
Sep 22, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
