Question about Plumbing
The zone in the back yard wont quit flooding the yard. I have replaced the zone valve, yet the heads still leak while the system is on. What should i look at next?
  • 2 more comments
  • andy_wachter Jul 14, 2009
    thats a possibility, how do i get a pressure drop without a leak?
  • andy_wachter Jul 16, 2009
    Yes it does, I think you are right i just dont know how to fix it. i looked at a pressure vaulve but i dont know if that will be the best salution.
  • 62 Answers
Could the zone be siphoning? The valve needs to have a pressure drop across the valve when the system is on.
Posted on Jul 14, 2009
  • Fred Jul 16, 2009
    Does the piping downstream of the zone valve run downhill?
  • Fred Jul 16, 2009
    I suggest that you install a vacuum breaker just downstream of the zone valve. That will prevent the downhill section from pulling suction on the zone valve after it closes. What do you think?
Husqvarna K 750 did a complete rebuild bearings seals cylinder kit coil and carb filters and all new pipes did a full leak test went for 5 min great came back later and just floods
If its a flooding problem then its a carb issue, and what you have replaced wont have effected the carb. I'd say you should either try stripping the carb and cleaning or replacing the internal carb gaskets. its probably just a sticking needle valve.
Aug 09, 2015 | Husqvarna Garden
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
I have a Toro 240-06-04 which is almost identical to the 250. My sprinkler system on the number one valve quit working. I thought maybe it might be a solenoid, so I replaced that and it still didn't w
Connect the wire form a working zone to the valve to zone 1. If the zone comes on you have short in the wire for zone 1. You can confirm this by connecting it to the valve that was working and it probably will not. If you have a spare wire connect it to zone 1 and in pin 1 at
the timer.
If valve still does not open and you replaced the solenoid (which is rarely the problem) the hydraulics are probably worn out in the valve. Purchase the same valve and switch out everything accept the valve body itself essentially rebuilding the valve.
Bad wire, no spare and you want to avoid running a new stretch. Merge this zone with a similar one by connecting both valves to 1 wire. If the pressure is good they should all work as 1 zone. Otherwise you will have to run a new stretch.
Apr 21, 2014 | Toro 250-06-04 1 in. FPT Electric Valve...
95 accord error code check engine code 21
This code is for a V-Tec valve control failure, which is why it doesn't come on until you hit 4200rpm. That's when the system activates. Check your connections at the V-tec solenoid/valve on the back of the head. You'll likely see it leaking quite a bit of oil leaking down the back of the engine from it. Don't bother messing with it, replace it. And don't use any kind of additives in your oil. (Slick 50, etc) These products notoriously clog the V-Tec valves. Good luck!
Apr 02, 2014 | 1995 Honda Accord
Yardman blower jut quit running like it was out of gas, restarted then did the same thing, now its difficult to pull the cord to strt
I'll guess and say that the carb flooded the engine and you have hydro lock.Pull the sparkie and clear the extra fuel.
The carb is at fault,IMO.
if the needle get a little dirt in there it will hold the float open and flood the motor.
Dirt.
Nov 16, 2012 | Yard Man Mulchinator QuickShift BlowerVac...
Water start leaking under the house when you pull the deverter up to turn the shower on, its floods out bad!
I'm assuming the leak is in the wall somewhere between the on/off lever or knob and the shower head. It is a good chance that it is the mixing-valve. It could also be where the shower head screws into the drop-eared 90*. If it is the mixing valve, it is either ruined, or a bad seal that might be replaceable. If it is busted piping the wall will have to be opened up to replace it. Good chance that the arm to the shower head is leaking at the threads where it screw into the wall. Good luck.
Mar 15, 2010 | Delta RP17453SS Standard Diverter Tub...
Replace Valve cover on 2002 Nissan Sentra
Are you sure the Valve Cover and not just the Valve cover gasket??
Any ways go to Auto Zone and pick up the Valve cover gasket, RTV Silicone selant, Gasket Scraper, and a can of Brake parts cleaner spray.
Disconnect the battery cable from the negative battery terminal, Remove the items which are in your way: Pull the spark plug wires off the spark plugs and remove them from their brackets, remove the PCV hoses, and remove the throttle cable from its brackets and position it out of the way.
Loosen the fasteners in this order, I believe there are 11 bolts holding the Valve cover down. Remove one bolt and count to the next 5th bolt and remove it and count to the next 5th bolt and remove it, do this till all the bolts have been removed on a circular pattern. Carefully remove the valve cover from the engine head.
If your just going to replace the Valve cover gasket,  Remove the gasket from the valve cover. Thoroughly clean the mating surfaces of the valve cover and the engine head. Use a gasket scraper to remove all traces of old gasket, and then use the Brake parts cleaner to clean any remaining oil from the surfaces.
If you bought a new Valve cover, Apply RTV silicone sealant to the gasket and engine head around the cutout areas of the valve cover. Note you still have to clean the heads on the engine. Lay the new gasket in the groove in the valve cover.  Reinstall the valve cover with its new gasket on the engine head. Tighten the bolts in the same order you removed it in. Do Not Over Tighten the Bolts that hold the Valve Cover down, you'll crush the new gasket and will get an oil leak.
Note: If the valve cover does not come off the engine head easily, use a block of wood and a hammer to bump it in an attempt to jar it loose. If absolutely necessary, you may slip a flexible putty knife between the head and the cover to break the seal.
If you purchased a valve cover gasket kit, don't forget to replace the small rectangular gasket and the spark plug seals as well while you have the valve cover off the car. You may buy some Brake cleaner to clean off all the oil which has leaked all over the engine.
DO NOT attempt to pry the cover off the head using a screwdriver or chisel. Be very careful not to introduce foreign matter into the engine. If you get anything (dirt, metal shavings, bits of old gasket) into the engine.
DO NOT over-tighten the valve cover fasteners. On the engine, the fasteners need only 17 to 34 in-lbs of torque.
Your A/C system has a leak in it. all system has a slow leak and common, You can get a re-charge kit at Auto Zone to save some money, but if your A/C needs charging again in 2 weeks or less then there is a larger leak due to a bad seal and is cheaper to have a A/C shop locate the leak and replace the seal that has gone bad.
Good luck and hope this help. keep me posted, be glad to help.
May 29, 2009 | 2002 Nissan Sentra
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Plumbing Logo
57 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
