Question about Acer Aspire T135 PC Desktop
Warning light flickering red light shows on top of box; machine v v slow
    Problem Solver:
  • 4 Answers
Clear your C-MOS.
Remove the little battery that is located on the Motherboard, and also there is a jumper on the MB with 3 pins. move it to pin 1 and 2 for 30 to 40 seconds. replace the jumper to pins 2 and 3 and the Battery.and reboot your system holdind the delete key to go and configure your System Bios to its default. F10 to exit and save settings. reboot while pressing the delete key again, then go see if the system is seeing your Hard Drive. If that works. reboot system as normal.
Please let me know the results.
Posted on Nov 16, 2007
Why do ABS and BRAKE lights blink on and off?
Search Results
    Brake Hydraulic System Red Warning Light - RepairPal > Auto Care Advice > Warning Lights
    If the red brake light blinks, or comes on and off intermittently, and there is no change in the feel of the brake pedal, then have the vehicle properly diagnosed by ...
    why does my brake light come on and then go back off? ' Yahoo Answers
    Jan 23, 2012 - today i was driving and my brake light came on and then went right backoff and was ok. my brakes work fine. ... Best Answer: Check your brake fluid, and top it off. There is a sensor that gets tripped when the fluid is low, and then goes off when it is refilled. (!) BRAKE light flickers occasionally while driving???!!? - Yahoo ...
    Oct 6, 2010
    Brake light flickering on and off? ' Yahoo Answers
    Sep 25, 2009
    My parking brake light keeps turning on and off? ' Yahoo Answers
    Feb 6, 2009
    My car's brake light turns on and off every now and then while I ...
    Dec 3, 2008
    More results from
    Brake Warning Light On, then Off - Car Talk
Jan 30, 2016 | Cars & Trucks
Vauxhall meriva 1.4 se 2011 engine is missing when warm at 30mph and bringing abs warning light up which then stays on and engine warning light flashers a few times and goes off no faults found what t
check your coil pack,remove both the screws ,disconnect the wiring plug and pull the coil pack up, have a look down each plug cap, there will probably be corrosion on the contacts or on the top of the plugs,this doesent always record a DTC
Feb 16, 2015 | Vauxhall Cars & Trucks
Red warning light is staying on when I switch on and drive my 2001 Grand Vitara dashboard (!) - what do i do?
all the above.
i cant see lamp, why not use photos so we dont need to guess, 1000 warning lamps used.
varies by country too. what lamp logos look like.
what it is , who knows? right, lacking a photo.
the key switch tells the warning box when you remove the key.
that buzz left in is the warning, take key out now.
seem the key inserted switch is stuck but id have to see lamp.
so yes that is switch not a sensor, (but sure one could call a switch a sensor.) and sure wires can fail. and connectors.
sure its electric, is sure is not vacuum.
the warning box can worn head lights left on
or exiting car key left in ignition.
do not fool with the key switch on air bag cars or risk death or broken neck with AIR BAGS.
read the manual, see the 1000 warning there.
and the words, DEFEAT the bags using X procedures first.
do so.
Apr 19, 2013 | 2001 Suzuki Grand Vitara
Red Brake Light Flickers
If the light in question is the red brake warning light, you should check the brake fluid and the parking brake first.
If it is the ABS light you should have the body computer scanned for trouble codes.
Sep 03, 2012 | 1999 Chevrolet K1500
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
No Coffee dispenses
That is exactly what I would've suggested, the brew unit is clogged. remove brew unit and try to blow through the top, if you get through then check the bottom. One of the chambers must be clogged. Another question is the coffee extract wet or dry grounds?
If wet then the block is on the top, if dry it ids on the bottom.
Feb 28, 2009 | Saeco Vienna De Luxe Espresso Machine
Digital phone/answering machine
The red blinking light is an 'event' light, it does not necessarily mean a message is waiting for you, it will also start to flash if you have a missed call.
click 'up' on the round button to show the missed calls list and it will stop flashing, at least it does on mine!
Dec 26, 2008 | Philips CD4451S/05 Phone
Electrical problem
Its possible you may have a bad Alternator
Jun 23, 2008 | 1998 Honda Accord
Problem with proscan 19LA25Q
Watching a movie tonight...and slowly there was odd behavior from the screen. No volume at first, then flickering, fragmenting and now, as the others only shows the red power. I have noticed some strange flickering the past 2 weeks or so. I thought it may be the cable, so did not concern myself too much. I believed that was the problem tonight as well. But the screen is definately not responding to the remote or manual button.
Mar 16, 2008 | Proscan 19LA25Q 19 in. LCD Television
Acer Aspire T135 PC Desktop Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
