Question about Dell Computers & Internet
I have swirls on my monitor. They are usually
I have swirls on my monitor. They are usually blue in color. They seem to be contained within windows or different areas on the computer. In other words, they do not cross from one button, window, etc. to another. The green start button has a blue swirls in it as does the clock.
    Problem Solver:
  • 9 Answers
Im guessing your using a CRT...? Please add some detail in this stuff, next time. Either magnet problems, or bad monitor.
1) Try moving everything away (Magnitized Problems)
2) Plug in another monitor
3) If it persists, call manufactor
4) Trash it :(
God Bless Bro
Posted on Jul 13, 2009
  • Hello Moto Jul 13, 2009
    Okay Bro, i double and triple reasearched it.
    Try Moving the cable (pc to monitor) wiggle it for better connection.
    The other reason would be Video Card, use step 2 (plug in alternitive monitor), if problem persists you need a new V-Card.
    If Not, its most likely the color gun in the CRT. Or someother monitor problem... $$$Time to open up that wallet ;)$$$
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
Compag laptop connected to LG HD TV. TV screen just show blues and greens, no reds. What do I need to do
To troubleshoot this, you must first start with the obvious. Check your cable connections/try replacing the cable. If this does not work you should then check the color settings in the tv. If that still does not work you can try connecting your laptop to a different monitor/tv. If the color shows up with the same problem, you know the issue is contained within the computer itself. Possibly bad VGA/HDMI Port or color management settings.
Nov 18, 2010 | Compaq Computers & Internet
Filter container
Yes , that is how they work. It is very reassuring to see all that dirt being collected isn't it?
Jun 14, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
It seems that the red is missing from the color monitor. It has blue and green hues but no red
Verify the cables and the connector pins of your monitor, at both cable ends. Ensure the cable is properly connected and the retainer screws are tight. A primary color's disappearance on a (S)VGA monitor is usually caused by a faulty contact in the connector (if you can, verify the cable also by switching with another PC's).
Jan 14, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Color on my dell monitor ,s1709wc, turned redish blue. Is it fixable? I would appreciate any help.
Try replacing your monitor cable. Also make sure to tighten the screws that hold it to connector on the computetr and the monitor.:)
Sep 07, 2009 | Computers & Internet
Change in color, computer problem inside TV
For "thechances", The LVDS cable has gone bad. This cable connect between the mainboard and the panel. The replace the cable will fix the problem.
Feb 17, 2009 | Vizio L32 32 in. LCD HDTV
Discolouring of monitor
There are several reasons for this most likely is the vga cable from the video port has undergone stress (sharp bending or crushing) this damages the cables inside and causes one or more of the colors to not display, usually red and or blue. odd it seems the green always is left unharmed when I see this...weird.
If you can I would replace the cable from the monitor to the computer. if the cable is sealed in then you may be able to find a replacement at a service center. and they could replace it for you
Apr 30, 2008 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Screen flicker, color swirls
Mine does the same has done since new, It was sent back and when returned it still does the same. If i tap the top of the screen it comes right again for about 10 miniuts
Jan 22, 2007 | Neovo F-417 17" LCD Monitor
Wondering?
If it works with one puter then that answers your question.The monitor is good and theres a video card or PC /driver problem. Try to uninstall and reinstall before replacing the card. Good Luck
Jun 10, 2006 | Philips Brilliance 109MP (White) 19" CRT...
Monitor colour problem
I assume you tried another monitor cable as well, if you didnt, it is one of the most common causers of unbalanced colors. if you did, my guess is you have a bad color gun. It's a very common problem. in this case, a trip to the local repair shop is necessary. before you do, you can try pulling out the VRAM and reinstall it. its a long shot, but you got nothing to lose. good luck.
Apr 04, 2006 | Proview InnoVision VM541 (White) 15 in....
Computers & Internet Logo
103 people viewed this question
Alun Cox
