Question about Plantronics Explorer 350 Wireless Headset
Battery? I charged the headset for a few hours but the headset won't turn on
0 characters
1 Points
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
Why does my headset turn on/off
Seems like what you say a power problem + the wireless band is a busy surroundig. Try some new batteries . It goes on so that's not the problem, it seems to me your signal is too weak to provide the working power and every day hours loading makes it die just faster.
May 18, 2014 | ASUS HS-W1 Wireless USB Headset
My PS3 headset won't charge it stays lit for 3
If there was no change using a new charger, I would suspect the battery is shot
Apr 23, 2013 | Headsets
The Headset Lifter won't pick up the calls. Nothing happens when I push the ear button to lift it up. I thought maybe it wasn't fully charged when I tried it yesterday. At that point, I made...
If the CS70 headset has a charge and beeps when you press the call control button, you may just need to re-pair or re-subscribe the headset to the base unit. Here is a link for the pairing / subscription instructions:
Plantronics CS70 Pairing Instructions
If the headset is not charging, the internal battery may be worn out and the headset may need to be replaced (the battery is hard wired and is not replaceable). The replacement headset is model 72910-01. Below is a link where you can purchase the replacement headset.
Plantronics CS70 Replacement Headset
Good luck from Headsets Direct!
Jun 24, 2011 | Plantronics CS70 Wireless Headset
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
GN 9350 Headset won't charge, blue light remains off I tried the solution of placing the headset on the charging cradle, then pressing both phone/USB button simultaneously The headset light...
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
Jun 21, 2009 | GN Netcom GN 9350 Wireless Headset
My tomible nokia phone has been dead for a while how long would it need to be charged so it can turn on.
Hi, charging a phone would take a few hours depending on the make and model of the phone, im assuming 1-3 hours....
Jun 12, 2009 | Nokia TMOBILE 6610 6610I Flexible Mini...
Charging H550
The indicator light turns red when the battery is
charging. It may take up to 1 minute for the
indicator light to turn on. When the headset's
battery is fully charged (about 2 hours), the
indicator light turns off.
Jan 09, 2008 | Motorola Mobility H550 - Bluetooth Headset...
H700 Loosing Charge Quickly
I think the normal talk time is around 6 to 8 hrs if your battery is holding less you probably have a unit with a faulty battery
how old is your headset
Jan 05, 2008 | Motorola Mobility H700 Wireless Headset
Plantronics Explorer 350 Wireless Headset Logo
Top Plantronics Headsets Experts
sonic boom...
sonic boom...
Nataly Roberts
Nataly Roberts
Ed Nelson
Ed Nelson
Are you a Plantronics Headset Expert? Answer questions, earn points and help others
