Question about Sony Handycam CCD-TRV318 Camcorder
DCR-HC19E flashing error code C:31:23
I have a sony handycam DCR-HC19E, when i switch it on it beeps and says reinsert cassette on the screen, with a error code in top right corner C:31:23. then it stops say reinsert cassette, and just says cover is not open. with the eject symbol on the screen, along with FN in the bottom right corner
SOURCE: cassette loading error 31:23
I have had this same problem several times. In all cases the problem has been a tape that has been run at the very end of it's lenght and it is too tighten. I loose the tape manually just a bit and it helps. Just be careful not to leave the tape too loose.
For loosing the tape you have to push the lock button with e.g. a pen and while doing that just take the tape out just a bit. Tape should be left at the level it was. It must not look like a loosen tape. If you get it out too much, just roll it back by twisting the reel again while pushing the lock button down.
To be able to loose the tape you of course need to open the protective lid first. For this there is a separate lock switch at the side of the cassette.
Posted on Mar 05, 2008
ctf1800
  • 4402 Answers
SOURCE: "Reinsert the Cassette"
go here
Posted on Jun 11, 2008
SOURCE: C:31:23 error with DCR-PC101 Sony camcoder
Had the same error message on my TRV-720, and could not come up with a solution for weeks until I found this website:
http://www.protechcam.com/wwwboard/messages/127.html
Now the fix you will not believe, nor did I at first, but requires you to power off the unit completely and "Smack it" a few times fairly hard.
Now you may do this at your risk, but I swear it fixed mine and all the other people listed at the above web site.
I thought it was a joke - but it works!!
Good Luck!
Posted on Jul 28, 2008
SOURCE: Reinsert Cassette Error
Hi, I had the same problem. When I inserted the new (or old ) cassette, it was showing me the same simbol as you are describing here.... The one thing to do here is to let it check in some CamcorderReparingCentre. After I let it to repare it they told me that there was some kind of engine broken , I paid £60 for reparing but my camcorder is working again,properly like before...
Posted on Apr 22, 2009
  • 85 Answers
SOURCE: My Sony Handycam DCR-HC26 started giving me
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Posted on Mar 20, 2010
Sony Handycam DCR-PC109 NTSC minicam--"Reinsert
The C31 indicates that there is a motor movement problem. I don't have the manual handy at the moment, but the :23 will indicate which movement is having the problem. This is not typically a DIY repair. I woul d strongly suggest that you check the fixed repair cost from a Sony authorized service center. This will not only repair the unit, but also reset it back to factory specifications.
I'll look up the error code tonight and try to update this.
Dan
May 26, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
When i insert the Sony Cassette i get the message Reinsert the cassette what can i do
there is a caasette called cleaning casette in the the shop itself
oyu can get it from the shop itself
its the same as the cassette
Dec 13, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
"SONY 'InfoLITHIUM' SYSTEM" Error
when I opened up the camera, the tape part of the cassette was hanging out. I tightened the tape and reinserted the cassette. this seems to have fixed the problem. hope this helps.
May 07, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sony dcr-trv480 video camcorder error
I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
May 04, 2008 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam CCD-TRV318 Camcorder Logo
226 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
