Question about Dometic Rooftop RV Air Conditioner
I set thermostat and it clicks on but nothing happens... Air doesn't come on .. nothing from unit on top of rv...
  • watersedg193 Jul 14, 2009
    thanks checked that not the answer.....
Check your circuit breaker. Thermostat is controlled by dc, compressor and motor are ac
Posted on Jul 13, 2009
AC Wont stop running.
a defective thermostat thats all
Jun 02, 2013 | Dometic Rooftop RV Air Conditioner
Durotherm Model 57915.331 - not cooling properly
Check the fuses in the rv to make sure you are getting power to the roof unit. If the stat clicks and nothing happens up there you have got a faulty stat, or, worse, a compressor fault.
May 19, 2012 | Dometic Rooftop RV Air Conditioner
I have two Friedrich PDE15KSB-C units. When trying to turn on the heat neither will kick into the heat mode. They both blow cold air only. When they are first turned on the air blows, and there is a...
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
Dec 14, 2010 | Friedrich PDE15K3SB Portable Air...
I have no voltage to my thermostat
Hi, I am not positive the control voltage to your thermostat will be on a RV a/c, most homes are 24 volts. I know yours would be less. If you have a 2-wire stat and this a/c is not working, take the two thermostat wires a touch and hold them together. Don't worry as this is safe and will not shock you. If the unit comes on and runs, you do have voltage there but the meter may be set wrong. If nothing happens, then you need to find the breaker for this unit to see if it as tripped. Reset it anyway. If still no power, you will need to find the transformer for this unit and check for power to it which will be high voltage/primary and power out which is the secondary low voltage which controls all low voltage controls such as the stat. If you have a wiring diagram on the condenser up top or most RV have a large book that tells you about your coache. If you have a diagram look for the thermostat as it will be labeled in the legend as a T with a circle around it or it may say stat. Follow to see where it gos from there, to the transformer or what and let me know. If the unit does fire when you jump out the stat wires, you will have to replace the stat. Please keep me posted on this. You may have a blown fuse up top cutting off power to the transformer also. You can ohm them out also. Keep me posted so we can solve this.
Sincerely,
Shastalaker7
May 11, 2010 | Dometic Rooftop RV Air Conditioner
Dead in the water
Have you checked for fuses in/at, thermostat ? What type of RV is this in? Power board should need to be replaced again, if at all, my guess is it's something else. Do you hear any "clicking" form unit when you move thermostat to other settings? Is nothing working at all, fan, furnace etc?
Colman unit is getting no power
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Sep 10, 2009 | Coleman Mach III Air Conditioner
I have a coleman electraheat rv airconditioner/heater. i think the thermostat has gone out on it. is this a replaceable?When i turn the thermostat knob nothing happens. the fan will run but the compressor...
The thromstat may be bad but it sounds like there is a loose connection where the wires plug on to the back side of the thromstat.
Any RV dealer should have the part or be able to order it for you
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
392 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
