Question about Hayward SAND FILTER, PRO SERIES
DE gets into the pool when recharging the filter???? I have a Hayward DE-6000 I have also inspected the filter elements and none of them appear to be ripped or torn. Thanks Bill
  • 110 Answers
You will get a bit of flow back when first turn on pump after service.
If you are not - use pool filter socks in your skimmer box (pool - not - pump skimmer). This will help lengthen the service times on your DE filter. Very helpful when 'Vacing' the pool :)
Posted on Jul 13, 2009
3620 hayward de filter earthe coming back to pool
take filter apart examine all the cloth elements if torn or ripped replace and that should fix your problem
Jun 23, 2014 | Hayward EC-40 DE Pool Filter with pump
De leaks into pool
one or more of the grids may be damaged. you will have to open the filter and inspect the grids (yes, they will have to be cleaned for the inspection)
Sep 22, 2013 | Hayward EC-40 DE Pool Filter with pump
Pressure in the filter, flow of water not good
take apart clean grids use TSP to degrease then put back in an recharge with DE
Jun 24, 2012 | Hayward EC-40 DE Pool Filter with pump
De is going back into pool and not stiching to the fingers
there is a tear in a element or not put together correctly
Jun 01, 2012 | Hayward EC-40 DE Pool Filter with pump
DE returns to pool after recharging my hayward ec50a filter allows
tear in DE elements replace or put back together incorrectly
May 30, 2012 | Hayward Pool & Spa
I just cleaned the filter and it seems like the D.E. is being pumped back into the pool
it's not specified which filter you have but it sounds like you have a tear in one or more of the grids or they were not put back in properly. Remove and inspect the grids, if there are no tears, put them back in carefully and attempt recharging with D.E..
Jul 29, 2011 | Hayward Pool & Spa
I cannot get the filter element cluster to release from the outlet elbow on my Hayward vertical grill filter. Any suggestions?
You did release the catch ... right? It should just lift out ... off the pipe and off the rod holder onthe other side ... wiggle it if necessary.
Aug 07, 2010 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
Have a model # EC-45 Hayward Perflex ,combine unit with pump can you tell me of any mantiance that might have to be done to this filter set , seems this year useing alot of DE dirt to get pool clean, when...
YOU HAVE A BAD GRID-GRIDS IN YOUR FILTER. TAKE THEM OUT AND FIND OUT WITCH ONE IS BAD . DO THIS IN THE SHADE DIRECT SUN KILLS THESE GRIDS.. WELCOME TO THE HAYWARD NORTHSTAR .. REMEMBER TO VOTE OR COMMENT .. IT IS THE FUEL TO KEEP ME TRYING TO HELP U GUYS .. JAY
Jun 10, 2010 | Hayward 1.5 Hp Northstar High Performance...
I have the Hayward EC-40 Filter, my problem is the DE is getting into the pool. What would cause this?
Broken/torn grid, o-ring bad in the housing by the grid assembly or grids not in manifold properly. Backwash, open the filter, remove and inspect the grids (the plastic bases too).
Jun 05, 2010 | Hayward EC-40 DE Pool Filter with pump
We have aEC-65 hayward pool filter with a 1HP motor why does the pump slow down run at higher pressure ?
I believe that this particular model is a DE pool filter. Is that correct? If you are operating with a media other than DE, let me know. Assuming that you ARE using DE:
1. You DE could be coated to the maximum with pool dirt algae, etc. To correc this problem, you need to bump the filter.
2. You could have an overcharge of DE. To remedy,
Bump-Drain-Recharge.
3. Restriction in return line caused by small
eyeball fitting. To correct, change to a larger sized fitting.
4. You could have a partial closed valve on a return line. You will just need to open the valve.
5. Make sure that your pump strainer basket and pool skimmer basket are not clogged.
6. Make sure that your pump impeller valves are not clogged.
May 25, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Hayward SAND FILTER, PRO SERIES Logo
253 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
