Question about Endless Summer 1501 Patio Heater
Difficulty starting pilot light, then when turn to low it extingishes
  • 3,230 Answers
If the pilot won't stay lit, the thermocouple may be loose or faulty, the pilot orifice may be clogged, or the pilot light's flame may be set too low and needs to be adjusted.
You can clear a clogged orifice with a piece of thin wire, such as a bread tie with the paper stripped off it. Be sure to turn off the gas to the furnace first. Also shut off the switch or circuit breaker that controls power to the furnace. Just poke the thin wire into the tiny orifice where the pilot flame normally burns to knock off any ash or debris.
Some pilots have a flame adjustment screw for adjusting the flame. To adjust this, refer to your owner's manual. Normally, this is simply a matter of turning the flame adjustment screw to achieve a full, steady 1 1/2-inch to 2-inch flame that doesn't have any yellow in it.
Good Luck!!
thanks
Posted on Jul 13, 2009
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
94 Chevy K3500 charge system light comes on, Batt now dead
could be a problem inside the alternator
you might want to have it bench tested at a store
Jun 30, 2012 | 1994 Chevrolet K1500
My heater started with no problem the first time earlier this summer. Since then I have not needed to use it, but tried to start it again this week. Pilot light is on, but when I turn the switch on there...
If you have a by-pass valve be sure it is closed or almost closed. Also check your baskets and clean your filter. All of these will give the heater low pressure and keep it from running.
Aug 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
We are having difficulty lighting the pilot light on our wards gas wall heater. Is there a diagram that shows where we are suppose to put the lit match and which way to turn the knob? Thanks for your help
you may have to push down on gas knob to start gas flow for pilot move flame so it licks thermo couple detector.
if thermocouple gets too old it will not generated enough power to keep relay open for pilot
Nov 25, 2010 | Montgomery Ward (223600UP) Heater
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
Pilot light keeps going out! difficulty lighting
Dirty pilot, you may need a contractor.Tom
Jun 18, 2009 | Heating & Cooling
2008 ktm 530 hard starting, hard to kick start, remove emissions
If it's a real bugger to kick start, install an 09 cam, works wonders. Go to KTMtalk.com to inquire about emissions removal
Mar 24, 2009 | 2008 KTM 530 EXC-R
Matsui MF160 Dishwasher
Unplug the cable and wait for about 15min. and then plug in cable back and turn on.
good luck
Aug 01, 2008 | Electronics - Others
Endless Summer 1501 Patio Heater Logo
93 people viewed this question
Top Endless Summer Heating & Cooling Experts
paulcarew
Tim Whalen
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
