Question about Belkin (54G F5D7230UK4) Wireless Router
Can connect via cable, but when we try wireless we cannot make connection, we have a secure network but will not accept our password?????
  • Douglessd
    Douglessd May 11, 2010
    Do you get an error message when you try and connect? You should also have a event log on the router itself. Have a look if you can find any error messages in there. What security type have you selected to use on your router? Do you select the same type on your PC? Try starting with WEP first as it is one of the more simple security choices.
  • 390 Answers
Hi
have you checked to see the access to wireless has been activated or deactivated.
also may have to check the channel of communication, any DNS, proxy settings
cheers
pls rate if this was any help
Posted on Jul 13, 2009
  • 3 Answers
Dear benaimee give me set number
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Mar 10, 2014 | Linksys Wireless-N WRT150N Router
Secure my linkys network
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go and your wifi is now secured thanks for choosing www.fixya.com and kindis ly rate this post
Jan 02, 2012 | Linksys 323 Computers & Internet
I am a Comcast customer with high speed internet. I am trying to get my wireless router to work on my lap top (Toshiba). The lap top will work if connected to the modem directly. However, when I try to...
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Aug 12, 2011 | NetGear WGR614 Wireless Router
Create a password for wireless internet connection
Hi. Open your browser and go to http://192.168.1.1
the default username and password is admin / admin.
Once you are inside the router, you will see on the left the menu such as network map, operation mode, advanced settings. Under advanced settings you will see the Wireless configuration where you can change the SSID (name of the wireless network) to any name you want. Then on the security you can select either WEP or WPA, i would recommend WPA and you set the password (letters and numbers or just letters) and save the settings and that's it.
Try to do this on a computer directly connected to the router (via ethernet cable) because any change on the wireless will disconnect you.
I hope this helps. Please do not forget to write and provide positive feedback for our fast/free support today. :D
May 25, 2010 | ASUS RTN12 4 Port 10100 Wireless N Router...
Wrt400n connects via ethernet cable, but won't talk wireless
you said every thing that connects with the ethernet is working. that means the wired part of the router is working. check the wireless settings of the router. Open the set up page of the router on the main computer. connect the main computer to the router with the ethernet cable.
change the wireless settings of the router.
WRT400N is a dual band router ( 2.4 GHZ and 5 GHZ)
You can create 2 different wireless networks. Make sure that the names (SSID) will be different for both the networks. For 2.4 GHZ change the standard channel to 6 and save the settings.
Go to wireless security and set the security mode to WPA Personal. set up password for the wireless network. You can use the same password for both the networks. Make sure that the Wireless MAC address is disabled.
Now try to connect to the new wireless network. and see what happens.
Click here for more information about routers
Mar 12, 2010 | Linksys WRT400N Router
Cant sign in to wireless password not accepted
Try to connect your computer with an ethernet cable with the router
Open the router interface using the default gateway that your computer is receiving
Under Wireless, select security and check the security mode and check the compatibility with your operating system.
Remove all preferred wireless networks from computer
If the compatibility is appropriate, and if security key is exact(case sensitive), this is sure to work
Jan 17, 2010 | Linksys WRT54G2 Wireless Router
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
Random wrong passwords
Any router that your connecting to wireless, without a password, does not have wireless security set up on the router.
Any other wireless router that you are trying to connect to that does not allow you to connect wireless, has wireless security set up and that same security must be set up on the wireless device (like laptop or desktop, whatever is not connected via ethernet cable.).
Reply back what you find and I will be glad to help more.
Feb 04, 2009 | Adaptec Computers & Internet
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Connection Issue
Hello There. What error message are you getting when you try to connect?
It would be better if you check the settings of your router. YOu need to hardwire the computer to the router via an ethernet cable. By default, you may access the router via http://192.168.1.1 using your web browser. No username, type admin on the password.
First, you may check the number of DHCP users that can connect to your router. On the setup page, Make sure that the No. of clients/DHCP users is set to 50(by default).
Second, go to the wireless tab then take note of your network name if you are connecting to the correct network. Under the wireless tab, click wireless security tab, verify that you are using the correct KEY.
If you are, remove your preferred networks on the computers then try to reconnect.
Hope this helps.
Aug 06, 2008 | Linksys Wireless-G Broadband Router
Belkin (54G F5D7230UK4) Wireless Router Logo
144 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
