Question about Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
How hard is it to change the seal and bearing in the power flo matrix? It is not leaking but is squealing bad.
    President:
  • Hayward Master
  • 1,378 Answers
You have to completely disassemble the pump and motor to replace a seal and the bearing(s). It is better to take it to a local electric motor repair shop if you are not sure how to complete these repairs. We charge about $60 total for the job and guarantee it a year. Most shops should be about the same.
Posted on Jul 13, 2009
  • nstrempel Aug 06, 2011
    who would I call to fix my pump? I went to the pool place, the guys in there just pretty much told me it was impossible to do, i told them no it wasnt, they backstepped and said ok maybe expensive to do like $180, and that I would be better off getting a new pump anyhow. I was a little ticked at that point. thanks for any advice you can give, my husband is deployed for the next year and a half, and I have no clue about pools....
  • John Prohaska
    John Prohaska Aug 06, 2011
    Zip code??
32097
Posted on Aug 07, 2011
Hayward power flo leaks
If it is just dripping a little and it is outside don't even bother until to freezes up. The pool will evaporate much more water than is leaking through the pump.
Jun 08, 2014 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
How to replace seal on hayward power flo matrix?
if seals leaking ruining bearings next to go replace whole unit
Jul 21, 2012 | Hayward 1hp Power Flo Matrix Above Ground...
How do I take my hayward Power Flo Matrix pump apart to replace the shaft seal?
The instructions are in your owner's manual, which you can also find on Google. No specialty tools are required.
Aug 04, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
It makes a noise like a bearing problem
The most common problem I have found with pool & spa pumps is that the pump seal wears out, it starts to leak, calcium starts to build up which causes it to squeal. A pump seal is not too too hard to replace. But if your pump is squealing with a "grinding" noise as well, then that sounds like bearings. At that point look for another pump
Sep 04, 2010 | Flotec Pool & Spa
Water coming out down by motor , pump is pumping but leaking. how do you get impeller off
sounds like a shaft seal leak..... cut power to pump ... unbolt the motor at the seal plate and pull motor from pump... take electrical cover off back of pump and hold the shaft at the middle (may have to do some digging to find it) of the back of the pump... now youll be able to remove the impeller by spinning it counter clockwise...
make sure you dont go cheap on the seals... and make certain to replace all seals on pump
(diffuser oring, housing gasket, shaft seals, and lid gasket
May 23, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Jul 19, 2009 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592 Logo
587 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
