Th42pz77u will not power up . red light comes on then blinks. 4 of the 4 fans come on
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 13, 2009
Sony KDS-R50XBR1 /(2005) Red stand-by light blinks 4 times.Tried new bulb (Philips) 1 week ago ,same problem as before .Whole new light engine replaced two yrs ago by sony.What happens is it will turn off...
The error code of 4 blinks indicate a fan problem.the fan is slowing or internitantly stoping. the fan is stallling. or the fans not getting power. Always rember anything that moves will eventally stop. this fan is on all the time. also there more than one fan. Listen closely to hear the fan. The fan is not difficult or exspensive repair.
Mar 04, 2011 | Sony KDS-R50XBR1 50" HDTV
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Only comes on for a second power light blinks red 4 times, stops then repeats
4 times standby red light blinking is an error code that shows that Fan problem in tv. Check following possible causes of that problem in tv:
1- Fan 1-4 power is not supplied. (AGU board).
2- Fan caught wires or harnesses.
3- Fan connector is not attached securely.
Thanks.
Jul 23, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
I have a similar problem with the Sony 60" wega SXRD rear projection TV. The green light blinks on the power/display LED and the picture comes on for a few seconds and then the screen goes black . Then the...
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
Apr 27, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
My tv is blinking red in the power indicator 4 times on my KDS-50A2000
I had the same problem. Red LED blinking 4 times. This error means that one of the fans is NOT spinning! To check.... unplug the tv.... turn the TV around to a well lighted area so that you can see the fans in the back... plug the TV in and turn it on. Watch for the fans in the back... and see if they are spinning. If not... that is the reason why the TV will not turn on! In my case, the fan next to the lamp was stuck for some reason. I removed the the cover of the TV from the back... and cleaned the fan, made sure all connectors to it were properly connected... and viola! The TV is perfect again! Enjoy!
Feb 05, 2008 | Sony KDS-50A2000 50" HDTV
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
