Question about Epson RX630 All-In-One InkJet Printer
RX630 "SERVICE REQUIRED" APPEARS ON LCD WHAT TO DO AND HOW TO RE-SET?!!
    Genius:
  • 1,341 Answers
Your model may not be included so look for 'unsupported model' or try the nearest model number in this:-
Go here to download the reset utility, remember to select English or you may get it in Russian:-
http://inkjetprinterhelp.us/epsonSSC.html
Then in your toolbar RIGHT CLICK on the SSC Service Utility and select SHOW MAIN WINDOW. With your printer online to your PC, select from there your printer in BOTH boxes, that is in the main list and also "installed printers".
Close the window, RIGHT CLICK again on the icon and select "Protection Counter", "Show current value".
You will then see both the maximum count allowed and the count of your printer, which at "full" will be very near to or just over that count.
Click OK to exit and then select "Protection Counter" again but this time "Reset Counter Protection".
Click it to set to zero.
REMEMBER, THE WASTE INK PAD WILL STILL NEED TO BE RENEWED OR CLEANED OTHERWISE YOU MAY GET INK EVENTUALLY POURING FROM THE PRINTER CASING.
Posted on Jul 13, 2009
How to reset fuser on my brother HL1870?
You can do whats called a Parts Life Reset Function.
This function is used by service specialists only when changing the periodic replacements parts to clear the life counter. To operate this function, press the "Go" and "+" switches together until the menu "RESET PARTS LIFE" appears on the LCD display. Select the required item "part name", using the "+/-" switches, then press the "Set" switch.
Your fuser error should now disappear.
Hope this helps!!!
Jul 19, 2011 | Brother HL 1870 Laser Printer
Can Epson rx630 be a network printer?
Yes it can but it needs to be setup as a shared printer.
Please click on this link and follow my instructions to setup a shared printer :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Apr 24, 2011 | Epson RX630 All-In-One InkJet Printer
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
RX630 SERVICE REQUIRED APPEARS
Jul 13, 2009 | Epson RX630 All-In-One InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Epson RX630 All-In-One InkJet Printer Logo
81 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
