Question about Olympus SP-560 UZ Digital Camera
When taking photos of moving items, sometimes it talkes a long time to expose and therefore I get pictures of the ground/sky etc
  • 736 Answers
Many cameras have a slow shutter release .. when you push the button you expect it to take a picture right away .. but the camera has to first adjust for focus and determine how much light is or will be available then set itself up .. this takes time but some newer cameras do it all very quickly .. one way to get around this is to first hold the shutter button down half way .. do this early just before your subjects are where you want them .. the camera will auto focus and set itself up .. keep the trigger in that half way position until the subject is in place .. now when you push the trigger the rest of the way down, there is very little lag ... make sure that you focus on something close to where your subject will be when they are in position .. .. another speed up trick is, if your camera has manual focus .. preset the focus for where you want it and that saves the time it takes to auto focus .. there are several digital camera reviews on the interent ..they will tell you how much shutter lag you can expect for different cameras .. that can be a great help when you are ready for a new camera or want to see where your present camera performs ..
Posted on Jul 13, 2009
PICTURES ARE BLACK
6 Ways To Fix Too Bright and Too Dark Photos
Recompose The Photo This is probably the simplest solution. When taking a photo of a scene with very bright and very dark parts, move your camera to eliminate one of the extremes. In the case of the band, I would have either closed the curtains for the shot, or recomposed completely and photographed from the window looking at the band, and the crowd behind.
Use Exposure Lock If you can't recompose the photograph, instead tell the camera what part of the image you would like to see. The rest of the photo will be either over or under exposed (too bright or too dark) but at least you will see your subject. You can dothis by placing the center of the image at your subject; half depressing the shutter to lock the focus and exposure; move the camera to re-compose the image; and fully depressing the shutter.
In the band image, the camera chose to correctly expose the scene outside, but even if the band member had been correctly exposed, the window would have ended up being over exposed and you would just have seen white.
Some cameras have an option called 'spot metering' to set the part of the image you'd like to be correctly exposed. If your camera has this setting, enable it before using the technique above.
Use Fill In Flash If your scene has a sunny background, but your subject is in the shade (or has a hat on), turn on the flash (as I explained way back in tip number 9 - Using Flash During The Day). I know it seems wrong but it really does work! By using the flash, your subject will look as bright as the background. This would have worked well for the child shot above.
High Dynamic Range Imaging This technique is not for the faintof hearted. It requires a subject that does not move; a good camera with the capability to set the exposure and output RAW images. A tripod and image editing software like Photoshop CS3 are also needed.
High Dynamic Range Imaging (or HDR for short) is a technique for placing both very dark and very light areas in the same photo. It requires you to take a number of photographs of thesame scene - each with a different exposure. First take the shot using the camera's recommended settings. Then, in manual mode and keeping the aperture at the same value as the first shot, take a sequence of shots - each shot having a different shutter speed (above and below the original). You'll have 5-9 shots of the same scene all in different exposures.
Merging the three images to the left creates the HDR image below. Thanks to Photomatix for the images.
hdrmerged.jpgNow import these into your favorite paint program. I use Photoshop, but you can as easily use a cheaper program designed specifically for HDR photos like Photomatix. Follow the HDR directions and the paint program will merge these images into one great looking shot!
Use a Filter If your scene is of a brightsky and a dark ground (for instance at sunset, or on a cloudy day), you can use a graduated neutral density filter. This filter cuts out someof the light from one part of the photo (the sky). This will correctly expose the ground and the sky without needing to use HDR. These filterscan be complex to setup, so I don't usually recommend them for beginners.
Fix The Original Photo in an Image Editing Program twobright2.jpgFinally, if you can't take another shot at the same location, you can fix the original image by changing the levels using a paint program. This works best when your subject is darker than the rest of the photo (because cameras lose detail in over-bright areas). I've brightened the band member in the top image using this technique and while it looks okay in thissmall shot, this technique can tend to amplify any noise in the image. The darker the subject, the harder time you will have fixing the image.
I discuss exactly how to use this technique in lesson 2 of my free Image Editing Secrets course. I have a tutorial for Photoshop, Photoshop Elements, Paint Shop Pro and the free Google Picassa.
- See more at: http://www.digital-photo-secrets.com/tip/140/6-ways-to-fix-too-bright-and-too-dark-photos/#sthash.58eENOTt.dpuf
Jul 09, 2014 | Nikon D3000 Digital Camera
Whilst watching SKy HD programs either HD or
You may be experiencing problems due to signal lost.These are sometimes caused by trees etc and sometimes the dish may need to be moved.
Dec 08, 2009 | Samsung LE37R72B 37 in. HD-Ready LCD...
White photos canon A470? i have a canon powershot A470 camera and there's a problem taking photo.. whenever i take a picture, it's either fully white or have white stripes on the pictures.. i thought it...
I had this problem too, I think it's the shutter problem, it doesn't close
when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
Kevin - Malaysia
Dec 06, 2009 | Canon PowerShot A470 Digital Camera
The picture come out to dark
This sounds like a very basic question. If you are a basic user, I suggest to move the camera dial to Auto to make sure you have properly exposed pics all the time.
Other things you can do to manually brighten up your photo:
- use lower shutter speed
- use larger aperture (smaller f number)
- use higher ISO
- use artificial light (flash, reflector, etc..)
Oct 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
Black flashing on screen where light is
This allows you to see where your photo is over or under exposed. It helps you see if the exposure is set right.
You can turn it on and off by moving the Up/Down/Left/Right button up or down. This will move you thorough the image data (shutter speed, aperature, file format...etc.). It should show "Highlights" on the screen when you have this selected.
Aug 15, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
CAMERA IS THREE MONTHS OLD. ON MY LAST OUTING I NOTICED A PERFECT CIRCLE SPOT ONLY IN SHOTS OF THE SKY. THE SPOT IS IN THE IDENTICAL PLACE ON ALL SKY SHOT PHOTOS NO MATTER WHAT FOCAL LENGHT IS USED. THE...
If you have another lens, switch it and take some shots of the sky. If the spot is gone, it probably was the lens that needs cleaning/servicing. However, it's more likely that there's dirt on your CCD. On your camera's menu, select mirror lockup/clean CCD (I can't remember the exact terminology but you get the idea).
After you select that, the mirror will stay up. Remove the lens and you'll see that the CCD is now exposed. Use a blower (don't use your mouth to blow as you will end up with spit in the camera) to clear out any dust/debris on the CCD. Don't touch the CCD.
Turn off the camera and you'll hear the mirror go back down. Re-attach your lens and try some shots.
Apr 13, 2009 | Canon EOS 40D Digital Camera with 28-135mm...
Outdoor photos mostly over-exposed.
take batteries out for an hour, this will reset to factory.  Give it a shot after that.
Mar 18, 2009 | Pentax Optio S40 Digital Camera
Shooting modes
The Shooting modes are as follows: PROGRAM (P)/AUTO Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Sports Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Nightscene + Portrait Suitable for taking photos of your subject in the evening or at night. This setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture. Landscape + Portrait Suitable for taking photos of both your subject and the landscape. This setting allows for both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting conditions. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is locked to wide-angle and cannot be changed. Indoor Optimum settings for taking pictures of family gatherings and groups of friends. This mode reproduces the background clearly capturing the atmosphere. Beach Suitable for taking photos at the beach under a bright blue sky. Colors of the sky, the beach and people are reproduced vividly. Snow Optimun settings for taking pictures where backgrounds are snow fields. Settings are similar to Beach settings and colors of the sky, the greenery and people are reproduced vividly. Fireworks Optimum settings for capturing fireworks in the night sky. Since this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture. Sunset Optimum settings for capturing pictures of the setting sun. This mode reproduces reds and yellows vibrantly. Again, this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Shooting modes
The Shooting modes are as follows: PROGRAM (P)/AUTO Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Sports Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Nightscene + Portrait Suitable for taking photos of your subject in the evening or at night. This setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture. Landscape + Portrait Suitable for taking photos of both your subject and the landscape This setting allows for both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting conditions. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is locked to wide-angle and cannot be changed. Indoor Optimum settings for taking pictures of family gatherings and groups of friends. This mode reproduces the background clearly capturing the atmosphere. Beach Suitable for taking photos at the beach under a bright blue sky. Colors of the sky, the beach and people are reproduced vividly. Snow Optimun settings for taking pictures where backgrounds are snow fields. Settings are similar to Beach settings and colors of the sky, the greenery and people are reproduced vividly. Fireworks Optimum settings for capturing fireworks in the night sky. Since this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture. Sunset Optimum settings for capturing pictures of the setting sun. This mode reproduces reds and yellows vibrantly. Again, this setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Olympus SP-560 UZ Digital Camera Logo
91 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
