Question about Sony PlayStation 2 Slimline Console
Play station 2 limeline scratching my game disks
Hi i hope you guys can help me i have one of those ps2 slimline consoles it has been working fine for some time now recently when i load game disks and play for a while i find that after i remove the disk i find the disk is scrathed pls help me as i cannot play my game disks cuase my console keeps on scrathing the games i play i also have a problem with my memory card when i use the ar max cheat codes the file saved in my mem card becomes corrupted the cheats work fine but when i use the ar max cheats a 2nd time they dont work anymore and i am left with a corruped ar max file that i cannot delete erom my mem card pls help i cannot use my ps2 slim console anymore i am really desparate plz e-mail me the solution at doobie1215@yahoo.com thnx for any solutions you guys can recomend
  • 6 more comments
  • Doobie1215 Dec 08, 2007
    hi guys i do not move my ps2 slimeline console when i am playing a game and before i move my ps2 i make sure there is no disk in the disk tray now my console does not read any games anymore pls help me pls also help me with my corrupted ar max file on my memory card thnx a lot guys
  • Doobie1215 Jan 12, 2008
    thanx a lot exGore I tried your solution and it worked I hope you can help me with my other problem concrening mem card nad the AR Max problem plz refer to my post thanx again you rule!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Nov 30, 2008
    darn i have tried replacing the thing with rubber from a rubber and it doesn't work.can you please add photos?
  • chrislvscynt Dec 27, 2008
    my ps2 keeps sounding like the game is being scratch to ****
  • himlover026 Jan 10, 2009
    ok so i did to many cheat codes on grand theft and now i cant leave my house i bought becasue when i leave it the whole game goes blank so im stuck in my house and i thought bye killing urself u could like escape the place u were and you know come out of the hospital but that didnt work and i tryd not using the memory card and i tryd pressing the start button to re start the game and that didnt work what do i do???
  • Anonymous Mar 25, 2009
    i have the same problems as his SlimLine Playstation 2 scratches the outer portion of the disc perfect circular scratch it is
    My PS2 is slightly used and it is 4 years old i was wondering if this problem can be repaired since my PS2 is in good condition only that it destroys my Games.
    Buying a new one would be my option if my PS2's condition is pretty bad
    I need help on this........ please i love playing PS2!!!!!!!!1111111
  • Anonymous Mar 29, 2009
    Yeah ok guys im having the same problem as most of yous, slimlines pad is worn out and my finafantasy 9 disks are getting destroyed with circle scratches, i was wondering, if i bought a ps2 the chunky one would it scratch the same? because ps2 chunky version doesnt spin does it?
    also if i turned my ps2 slim on its side so its vertical would that reduce the scratches due to the vibration is less?
    if anyone can help me it would be grately apreciated
  • mccook May 11, 2010
    please add photos
I do not think moving the console while playing is the problem.  It might scratch, of course, when you move while you're playing, but what when you're not and it keep scratching disks?  Problem the people who have posted here, haven't been moving when playing.  My PS2Slim is scratching my disks too.  I have put a new unscratched disk onto it, and made it load the game, and just for few minutes I turn it off and take the disk out, I see a small scratch on near the outer side of the disk.  And it is doing that constantly, on the same place, without moving the console.  The console is not on vertical position, but horizontal.
I was reading somewhere that when the disk starts to spin it vibrates, which makes sense.  If you lift your cover and check, there is a piece of small cloth like or sponge, I don't know near the top part, near where the disk lense is, it kind of like keeps the disk still.  But from time to time of being using the PS2, that small thing gets worn out it could be probably that thing that is not working as it is supposed to be, so the disk starts to vibrate more than it use to and then the disk gets scratched.  This is just an hypothesis.  I still need to find a way to replace that small piece to see if that's the problem.
Posted on Dec 25, 2007
  • 1 more comment
  • Steven Dec 26, 2007
    Update to my previous post.  I have replaced that small piece of spongelike material that kind of keep the spinning disk still or not to vibrate.  I have tested 2 and 3 games already, and it hasn't scratched them yet.  I will keep testing some other disks more and post the results here.
    Regarding with what I have replaced that white spongelike thing, I used those double contact tapes that has a white piece of sponge in between.  I used two of the same size and pasted on top of each other, and then put it on the place the original was (of course you'll need to take that off first, please if you do this, check if yours is worn out).  Use a small scalpel to take the glue of the side that will make contact with the disk out and leave one side with glue so you can paste it there.
    Update to my post.  Last night I tested playing 2 more discs like for 30 minutes or more and haven't seen a scratch after I replaced the small piece of white spongy thing that kind of holds onto the disc's border.  Seems like when that thing is been worn out, your discs vibrates more than usual and leading to the scratch of discs.  At least, it had worked for me.  I don't want to change the old one back to see if it starts scratching again.  I'm keeping the worn out piece just in case I need it, I think it will be used as referrence.  I can add some pictures if anyone requests so.  Have a Merry Christmas and happy New Year.
  • konzen_yuki Dec 03, 2010
    ex gore..i face the same problem as yours..i would to know more about the solution and how to fix the spongelike thing..could you teach me?
    Problem Solver:
  • 5 Answers
Replacing the small peice of padding does seem to work, i took a more budget approach and made a new pad from a cotton pad and a slip of masking tape to keep the shape, then i simply super glued it (very carefully) over the old worn pad. I ran an old demo disk for ten minutes or so to let it wear a healthy groove into the new pad and when i removed it, no scratches! It seems that the superglue used gave it a firmer shape too which supports the disk better I would imagine. BE VERY CAREFUL NOT TO GLUE THE LITLLE PLASTIC PAD HOLDER INTO PLACE - IT IS SUPPOSED TO MOVE SLIGHTLY! Also, be careful not to make your pad too hard or thick, as that cant be good.
Posted on Jun 16, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Your disks get scrached most probbably because you move your console when your PS2 is running and there is a disk in the disk tray. Always turn off you console when moving it around.
Posted on Nov 16, 2007
I have bought my new ps2 but my problem is that it cant read any memory card that im inserting on it... it can work perfectly but my only problem is that it cant read any memory card, plz...help me guys....
Posted on Nov 16, 2008
Wow, just found this, and I must say, as my PS2 slim has been "out of order" for almost a year now, your solution exGore, was awesome! Thank you so much! Time to go play some Socom!
Posted on Apr 19, 2008
Wont play some games
mabye its becuztyhe disk ois scratched or lik i said to another guyits not tha rite type of disk
Jan 21, 2010 | Sony PlayStation 2 Slimline Console
The game wont play because it says need playstation format disk
Maybe you're using a used game... check if the game has scratches on the back, if it does, most likely the game won't work.
Ps2 usually has this problems.
Dec 09, 2009 | Sony PlayStation 2 Slimline Console
During games the console freezes in different parts. it happens in different games and i have to wait for it to load the landscape before i can play again
Sounds like either a scratched disk or an overheat. Put your PS2 in a well aired out area where it can breath. Check to make sure your disks aren't severely scratched either
Nov 27, 2009 | Sony PlayStation 2 Slimline Console
Rockband PS2 brand new disc will not read
I had a similar problem with a "Metal Gear Solid 2: Sons of Liberty disc".
Disc would not play, but it was in mint condition. I had no choice but to return it to the store and get a new copy, which worked.
There must have been an error when the company burned the disc.
Dec 24, 2008 | Sony PlayStation 2 (PS2) Console
Ps1 games
ps1 game dont work on the ps2 try ps2 games they will work
Oct 09, 2008 | Sony PlayStation 2 Slimline Console
Sony play station 2 slimline
your disc is dirty and has lots of scratches on it get a new disc
Jun 28, 2008 | Sony PlayStation 2 Slimline Console
Play Station Disabled
just throw ur ps2 in a dustbin
May 27, 2008 | Sony PlayStation 2 (PS2) Console
Slimline PS2 decides wich games it likes
The only Idea I have is that your Laser lens may be melting. This would explain the eratic behavior you describe. I have found that in the progression of the meltdown, the Laser hates reading silver backed discs at first. Then it will progress to not reading DVD's at all. Then nothing.
You need to look at your lens up close with a Magnifying glass. To do this you must take the console apart. you will need a new laser if you find that melting of the lens and or its support frame are melted.
Nov 27, 2007 | Sony PlayStation 2 Slimline Console
Light guns
I don't believe ps1 items except memory card and controller work don't know much 'bout ps1.
Nov 15, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
3,267 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
