Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Model #WSF26C2EXY02. Why is ice maker not making ice?
Tried thawing out freezer, no good. Tried pouring water directly in reservoir, makes ice, so that's OK. Water dispenser works, so line to fridge OK. Replaced water filter. Maybe water line inside fridge is frozen? Know the best way to unfreeze it? Thanks!!
    Top Expert:
  • Whirlpool Master
  • 9,098 Answers
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Posted on Oct 15, 2015
SOURCE:
How do you remove icemaker to check if water tube is frozen?
the ice maker is finished. get the ice maker model number and refrgerator model number and buy/ install a new one. It would be a good idea to replace the electric water valve to the ice maker as well.
Feb 07, 2014 | KitchenAid Architect Series II KSRJ25FXMS...
No water flowing into the ice maker reservoir. I poured water into the reservoir, but no ice dropped after 10 hours. Next day I unplugged refrigerator opened freezer door and thawed it out for about two...
Well, if the ice maker were working properly, when you poured water, assuming you poured A, enough water, and B, not too much water, you should have seen some cubes drop into the bucket. But since you did not get any ice cubes, I would have to say the reason your ice maker is not making ice is because you have a bad ice maker. Its not receiving water because it is not cycling.
Oct 09, 2010 | KitchenAid KSRU25CR Side by Side...
Ice Maker is dead on Kenmore Elite TRIO bottom freezer with French doors. This model has separate water dispenser inside fridge on left and ice maker in bottom freezer. We've tried replacing the filter,...
you can check the fill tube in the freezer make sure it is not blocked with frozen water. if you can disconnec the water supply line from the fill tube try and reset the ice maker to advance it to a new cycle and if water come out of the supply line the you knwo there is a blockage if no water comes out the the ice maker may be bad or the fill valve is bad. last thing you may need to call a service tech out to find the problem.good luck i hope that this has helped some what.i would like to knwo how thing go for you
Jan 22, 2010 | Freezers
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice cream not firm
The freezer bowl is sensitive. Go ahead and thaw it out until you can hear the liquid swishing around inside - usually letting warm water run through it is sufficient for thawing. Then refreeze the bowl, making sure the bowl is sitting flat/level in the freezer. When making ice cream with this unit, letting the freezer bowl sit out for even 20 minutes can unfreeze it enough so that you only get sludge. Do not remove the freezer bowl until you are immediately ready to pour the ingedients into the bowl. You can even pre-chill your ingredients by letting the ingredients sit in the freezer for about 15 minutes - although I have found that this usually has the opposite effect of what you have just experienced --> the ingredients usually freeze up so fast that the mixing paddle is no longer able to turn.
-Tha Mp3 Doctor
Mar 16, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Frigidare ice maker making slabs of ice, not cubes
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Nov 16, 2008 | Frigidaire Dryers
My freezer bowl not freezing anymore I let in the freezer more the 24 hours and it's still liquid
Thaw the bowl and re-place it in the freezer - make sure it is sitting perfectly level. Don't remove the freezer bowl until you are immediately ready to pour in the ingredients - letting it sit out for even 5 minutes will be too long, as it thaws quickly.
Jul 17, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Whirlpool icemagic
fill cup of the icemaker is frozen, take your finger and feel in the little white square cup at the rear of the ice maker, if you feel ice in it then thaw it out wit a hair drier and you are good to go
Apr 08, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
621 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
