Question about Canon EOS-20D Digital Camera
Flash the flash on the camera not working
  • Gary Morris Nov 17, 2007
    When I push the button to raise the flash, it makes a whirring sound but the flash doesn't pop up.
    Problem Solver:
  • 15 Answers
We usually find some sort of sticky foreign material (juice, soft drink, or any other sticky material) has been spilled on the camera. This prevents the pop-up flash from lifting. Inspect the pop-up flash for cleaning. If the material has gotten under the flash head the camera should be taken to a competent shop for cleaning. There are, as well, swiches under the flash head that fail. It could be any of these problems. Take it to a good repair shop.
Posted on Nov 19, 2007
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Camera flash is not working. Batteries in the
If camera flash is not working it must be the high - intensity discharge (HID )lamp of the flash assembly that got busted which needs to be replaced. Parts are available in every local camera shops and they are not that costly. So consult your nearest camera repair shop and have it replaced with a compatible HID flash lamp.
Take care!
Jul 08, 2010 | FUJIFILM instax mini 7 Digital Camera
The flash is not working on my Fuji FinePix F402 Digital Camera
If the flash is faulty, it will most likely be to expensive to repair. You can still use the camera, though. Indoor photos will be to dark unless you turn off the flash. Cycle through the flash modes untill you get the Suppressed Flash symbol. Flash mode button is next to the zoom button. Watch out for camera shake when shooting indoor without flash.
Mar 27, 2010 | Fuji FinePix F402 Digital Camera
Can't get the flash function to work on the vivicam 8018 camera
There is a switch on the side of the camera that needs to be in down position (scenery) for the camera to flash. Worked for me.
Dec 26, 2009 | Vivitar ViviCam 8018 Digital Camera
When connected to the camera, the flash will not recognize the camera or the camera will not recognize the flash. How do I correct this problem?
First make sure that your flash is DESIGNED to work with a digital camera. A flash that was designed to work with a 35mm camera will not work with a digital camera.
Oct 23, 2009 | Nikon Speedlight SB-600 TTL Flash
GE a735 digital camera flash not working, Camera works, but flash not working when shutter is pressed
Make sure your flash has not been turned off, check your settings. You may try changing your flash settings, most cameras have a setting for fill flash (flashes every time). If it still is not working make sure your batteries are fresh. If you have tried these two things, I would say its broken. If its still under warranty take it back, if not just use it and forget the flash. Flash is useless past 12 feet in most point and shoot cameras.
Aug 21, 2009 | GE Cameras
Flash does not work
Flash unit is defective and needs to be replaced as per following part number... (if you have camera repair experience then can do it your self because electric shock risk in involve in flash unit handling)
A-1249-950-A ..ST BLOCK ASSY
Above part is available in Part Store.
Dec 26, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Fix flash on kodak z740
to try if the flash is working..
*Turn off the camera.
*Install a set of new or fully charged batteries into the camera.
*Turn on the camera.
*Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash.
If the flash of your camera will not work, refer to for interactive troubleshooting and repair
Apr 09, 2008 | Kodak EasyShare Z740 Digital Camera
Flash dosen"t work
My camera is Praktica DC5.0 megapixel. The green light comes on when i want to take pictures, but the flash doesn't work
Dec 17, 2007 | Cameras
External Flash can't fix
Its becoz that flash is not compitable with your camera. You should buy only flash that are compitable with your camera.
Nov 16, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
Canon EOS-20D Digital Camera Logo
77 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
