Question about Ariston Technologies Washing Machines
ARISTON AML 125 The washer-dryer continuously loads and unloads water. On-off / door lock led flashes rapidly. Delay timer super wash and 1200/600 lights flash. Can you please advice on how to solve this problem?
  • 209 Answers
SOURCE: aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Posted on Sep 14, 2007
SOURCE: How do I translate the manual?!?
hi i have this machine ,when you open the draw on the left hand side ,the detergent goes in the largest section ,fabric softner in the mesh one ,pre wash (bleach etc in other one)now for washing just use cycles 1,2.3,or 4 one being the longest cycle 4 being shortest middle knob is temp, last knob is dryer, if you want it to dry automatically after a load of washing put it on the iron or other to window looking symbols ,otherwise if not drying have it on 0.i would send u a manual but i've lost mine hence why i'm on his site at all.Hope this helps get u started.
Posted on Jan 27, 2008
  • 53 Answers
SOURCE: Hotpoint BWD129. Door lock flashing rapidly,
sounds like your pump/filter is blocked. clean everything out.POWER OFF.
Posted on Oct 16, 2009
MNfisherman
  • 11896 Answers
SOURCE: Have a AML 125 front
The door switch may be bad. You can test it with an ohmmeter. Do check the pump to make sure it is not loose or broken. Also check the drain and drain screen to make sure it is not clogged.
Posted on Feb 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Ariston delay timer problem AVXL129 washing machine
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Aug 12, 2007 | Indesit W 123 Front Load Washer
The On-Off door lock LED flashes rapidly at the same time with Delay, Timer and Rapid LED. and it wont start.
Many times faults like this can be cured by Uplugging the washer from the mains power supply and leaving for 10mins. Also check all filters, drain and supply lines are clear and not kinked.
May 04, 2011 | Ariston Technologies AW129NA 16 Lbs Front...
Looking for user manual for ariston AML 125 in english
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/HOTPOINT-ARISTON/AML%20125-_M
Click on download the complete user guide. It would direct you to a new page.Rate the questions.Once done, a link for ' download ' would appear. Save the manual on the desktop.You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 21, 2011 | Ariston Technologies AW125NA 13 lbs. Load...
We just bought a second hand Ariston Washing Machine model AVL 95. It works fine all programs, but when it goes to spin, it starts to spin, speed up, and then stops with an error (Delay Timer flashes and...
its the drain pump see if you can take it out there small and easy to get to,also you see a black ribbed hose that goes to the drum to the pump see if there any thing in it.The drum is inclosed.try running 2xclorox through machine.
Jul 05, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Aml 125 washer - washing for hours
Sep 07, 2007 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
105 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
