Question about Gaggia Classic Espresso Machine
Gaggia Classic Spurts Everywhere
I've tried different makes and grinds of coffee. But all I want is Lavazza Rosa in the morning and, Lavazza Decaf in the evening. No matter how much coffee I put in or how I tamp it down or whichever insert, 2 out of 5 times the coffee comes out horizontally at right angles showering the kitchen. This didn’t happen with my old machine. Any suggestions would be welcome.
  • Anonymous Mar 28, 2014
    Coffee comes out too short... How do I make a longer coffee?
    Scholar:
  • 36 Answers
Hi there if your coffee is spurting out the sides it is because the group gasket is worn or has gone hard through use and now needs replacing. Basically when you twist your coffee handle on it doesn't always form a perfect seal and so the pressure causes the coffee to spurt out the sides. If you are not sure where to get parts get in touch with David at coffeeservice@live.com and he will be able to sort you out.
All the best
LaPavoniBoy
Posted on Jul 14, 2009
  • kilroy9 Nov 16, 2010
    My machine is doing this and it is brand new. I pulled one shot before it started spewing. It is exiting through the proper holes...just spraying instead of dripping. I just inserted the small plastic piece that I thought was only for the "perfect crema" system and it seems to be under control. Is that the fix or should I try to find out if I had a faulty group gasket...if so, how do I know that it is bad?
  • bobbarrista Dec 27, 2010
    Hi, my Gaggio Classic is doing exactly as you described, spurting water/coffee out at right angles from the delivery spouts.
    What do you recommend to stop this happening?
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
Sep 07, 2014 | Gaggia Classic Espresso Machine
Netherlands
Hi There,
That sounds like your coffee grind or tamping needs to be adjusted or the shower screen may need cleaning.
Pressurised water looks for the weakest point when extracting and if grind is too coarse or tamp is off, it will come out one side mainly.
If you don't have a grinder add extra coffee in the portafilter basket.
If is still spurts with the portafilter off - the shower screen may need cleaning - take it off and soak in coffee cleaning solution. Puly Caff coffee cleaner
Oct 21, 2017 | Gaggia Coffee Makers & Espresso Machines
My gaggia titanium is dispensing very weak coffee. No idea why. Have tried different beans. No change.
try a finer grind coffee , you cant use a "store" grind in a cappuccino machine it requires a much finer grind than that
Dec 07, 2011 | Gaggia Titanium Espresso Machine
When I'm making coffee in my Gaggia Classic, the brewing basket tries to unscrew (twist to the left). I have a feeling some part may have warped and need to be replaced. What would it be?
The only part up there is the group gasket, it will move the handle if there is an excessive amount of pressure, try adjusting the grind and or tamp and if that does not work then replace the gasket.
Apr 08, 2010 | Gaggia Classic Espresso Machine
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Nov 05, 2008 | Gaggia Tebe Espresso Machine
? Am I trying to use coffee ground TOO FINE
On my Gaggia Machine I use an Gaggia MDF Grinder on 8 or 9 setting for the best flow. I only use as low as 4 with my Presso Manual Machine
Nov 05, 2008 | Gaggia Classic Espresso Machine
No crema on short black
Make sure the coffee is a fine grade...place holder in machine for 6 mins before filling with coffee and ensure the filter holes are clear and dry.
Oct 20, 2008 | Gaggia Classic Espresso Machine
Coffee spurting everywhere!
Unlike the other person offering a solution I have experienced this problem like you when making the first cup. I found that sending a blank shot of water through first does the trick before putting the coffee grounds on. Hope this helps.
Jun 09, 2008 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
465 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
