Question about Dishwashers
The dishdrawer dd603 leaks and fills up the bottom tray and starts beeping. the washer was not running.
  • 64 Answers
Need to have the lid motors changed part cost is arond $47.00
Posted on Jul 14, 2009
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Fisher and paykel dishdraw model DD603
P2 is for drain. Make sure there is a bit of water in the base of drawer before you start P2 otherwise the rotor may rub and burn. You can run the diagnostic with drawer open. Be careful not to start P1 as the wash water will splash and flood the dishwashwer.
Jan 28, 2013 | Fisher and Paykel Dishwashers
How do I take the back of my dishdraws I seem to have a leak coming down the bottom back cormer
Hi there Kathy, I'm afraid you cant take the back of DD603 to gain access to inspect for the leak you will have to take the draws out I hope this help, regards Gary.
Oct 30, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
FP DD603 fills water, stops error 01 crossed faucet symbol
I had the opportunity to work on a Fisher & Paykel DD632 dishdrawer a couple days ago. By the way, I am a big fan of Fisher & Paykel equipment--if you ever have the opportunity to work on one, you'll see why. The engineering is elegant in its simplicity. Well-engineered equipment is actually much easier to work on because they have designed serviceability into the product.
Anyway, the problem with this particular dishdrawer was that the top drawer (with an 11 minute wash) was giving an F1 error code after the initial rinse, about five minutes into the cycle. The F1 code indicates an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose.
So, I put the dishdrawer into diagnostic mode and tested the fill and pump out functions--everything was peachy. I ran the top drawer in a normal wash cycle and, sho 'nuff, the drawer faulted out on F1 after the first rinse. Well, Houston, we had a problem and it was time for the Samurai to break open a can of whup-*** on this dishdrawer. First thing I did was pull the front panel off the drawer.
Fisher Paykel DD603 dishdrawer with the front panel removed.
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gook us. None found--my quest continued.
The next step to remove the bottom drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the bottom cover panel removed:
Fisher Paykel DD603 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
I had a flash-back to my Navy days and heard Petty Officer (AT1) Crowe's voice in my head, "Here, take this ruby red eraser and clean off them contacts. That'll restore the current flow for that circuit. Good to go, Sailor." You gotta understand, Petty Officer Crowe was my technical guru in the Navy--he taught me many of the practical and theoretical troubleshooting skills that I still use today.
So I cleaned the contacts as instructed by Petty Officer Crowe's mental image in my brain and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
OR ,if this is not the case next thing to look for is
If you have problems with a plugged drain hose
Dishwasher Drainology
Your dishwasher sounds like it's working up a storm, draining all that yucky dirty water out, but you open the door and all that dirty water is still there. Houston, we have a problem. OK, grasshopper, go grab you a cold one and hang on for a magical mystery tour into what causes dishwasher draining problems, also called the ancient and mystical art of dishwasher drainology. Let's take 'em one at a time:
* Using Too Much Detergent
Some fancy dishwashers with electronic controls have sensors that detect when the pump is not pumping water. Using too much detergent creates a great head of foam in the dishwasher basin, like pouring a beer too fast into a glass. So if you use too much soap in one of these so-equipped dishwashers, the sensors think the dishwasher is empty and cuts off the pump (For you gadget geeks out there, it senses the pump work by using a sensing resistor in series with the motor main winding.) While we're talking about detergents, that store bought stuff you're using is screwing up your dishwasher
* You Forgot to Remove the Disposal Drain Port Knockout Plug
# This usually only applies to the situation where you just installed a disposal and connected the dishwasher drain hose to the drain port on the disposal. Believe it or not, this happened to me on my first disposal installation job, too...no, not really. But I have seen many a grasshopper stumped by this.
# Drain Solenoid Not Opening
Some brands, notably GE/Hotpoint and Magic Chef, use a drain solenoid to open and close the dishwasher drain port. If this solenoid isn't opening during the drain cycle, could be a bad timer or solenoid.
# Worn Pump Impeller
Other dishwashers, like Whirlpool and KitchenAid, don't use a drain solenoid but instead reverse the motor to drain the basin. One possible reason for poor draining in this type of dishwasher is a worn pump impeller. You usually figure this by elimination...no, not that kind of elimination you dawg! I mean, if all the other suspects listed here check out OK, then you've got a worn pump impeller. The rebuilding kit for this repair is very inexpensive and is a great beer drinking project.
# Kinked or Plugged Drain Hose
Drain hoses can become kinked or crimped from poor installation, stuff being moved around, lots of reasons. It happens.This page on drain hose configuration shows you several approved drain hose layouts. Drain hoses can also get plugged from gookus. Plugs usually occur at the one of the drain ports--either on the dishwasher or at the other end. The best test is to take the drain hose off at the dishwasher and pucker up and blow like a fish. Yep, it can be pretty nasty putting your mouth on that stuff but, hey, that's why we appliance techs make the big money.
# Air Gap Plugged with Gookus
Plumbing codes may require an air gap in your dishwasher drain hose and many houses have 'em. These air gaps do a great job of keeping sewer water from backing up into your dishwasher but they can become a source of problems, too. Sometimes, they'll get plugged with gookus and they'll need to be cleaned out. If it's real bad or corroded, do yourself a favor and install a new air gap kit.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My model number is DD603 The top dishdrawer is draining into the bottom dishdrawer. What is the code to reset the drawers?
the check valve in the bottom drawer may be clogged or defective. the two drain hoses are probly connected to become one.
Jan 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
My f & p dishdrawer model DD603 has fault code F1:
Yes, you need to gain access to the inside bottom panel of the dishdrawer and drain/dry the water in the bottom panel. When all of the water is gone the polystyrene block will lower and turn off the flood system. You then need to find the reason the unit flooded and rectify it or the unit will just do the same thing again.
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Possible pump blocked
dishes have white film glasses are foggy
Jan 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top Drawer light is out-display eratic powers on and off at will.
Below is the service manual link and a web site that I found. refer to the lower section where a person writes in that the fixed the flooding with a hairdryer. I hope this helps, they seem like fantastic dishwashers.
http://www.scribd.com/doc/6462163/DD601V2-Manual
http://fixitnow.com/wp/2004/10/25/appliance-repair-revelation-fisher-paykel-dd602-dishdrawer-f1-code/
Mat
Please rate me
Nov 30, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
193 people viewed this question
Top Dishwashers Experts
