Question about HP LaserJet 3050 All-In-One Printer
I have 2 telephone lines 23481629 & 23480095. i get faxtone on 23481629 & no fax tone on 23480095
  • HP Master
  • 1,684 Answers
The HP 3050 laser multifunction is not set to handle 2 incoming fax lines. If you need that then you have to add a line switcher such as one from Command communications CS3500
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 17, 2009
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I can not get a clear dail tone.
Unplug your fax line and plug in a basic telephone and see if you can get a clear dial tone. If its still bad with just a telephone plugged in then your problem is either within your building or with the outside line...if its ok with a telephone then the line is ok and you may have a dad cable plugging into your fax machine or something wrong with the fax machine itself.
Oct 20, 2010 | Office Equipment & Supplies
Fax machine kicks in after only three rings and cuts off connected telephone
Make your fax setting as default. Then make the setting as direct faxtone. then directly sender get the fax tone.
Aug 24, 2010 | Brother MFC 490cw Color Inkjet...
There is a fax tone when dialling our telephone number.
Set your fax to MANUAL MODE. You will have to press START when you know you are getting a fax.
This is the only way it will work without a dedicated fax line.
Nov 30, 2009 | Canon FAX-JX200
HP LaserJet 3050 All-In-One Printer Logo
Seeker5211
Seeker5211
