Question about Toshiba Satellite A100-S8111TD Notebook
Desktop not appear
Computer start,booting comp.but desktop not appear
In Safe Mode , I can see only safe mode written on all four corners and screen remains dark.
  • 85 Answers
Sounds like either you have a process running that is locking out the explorer shell from running properly, or you have hard drive corruption (which is getting pretty rare). Try opening task manager (control-alt-delete) in safe mode and then looking for any processes running at the top of the CPU stack, and then cancel them one by one to see if explorer (desktop) appears. Actually, if you can get task manager up, click on APPLICATIONS along the top, and then NEW TASK at the bottom and then type in EXPLORER and AFAIK it should load your desktop (or try to).
If these all fail, you want to try to re-install the OS, and also check the hard drive for corruption using diskcheck.
Good luck...
Posted on Nov 16, 2007
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
How do you put the computer in safe mode on a HP pavillion?
If I remember correctly, for Windows XP:
Click on 'Start' at the bottom left of your screen
Click on 'Run' - should be on the right side of the Start menu towards the bottom.
A box will appear at the bottom of the 'Start' menu. Enter "msconfig" (without quotation marks), and press the Return/Enter Key.
A new window will open with several tabs. Click on the BOOT.INI tab to open that, and click in the square box first on list by /SAFEBOOT. There are three variants of safe mode. For now, choose 'Minimal' (click in the circle by that word). Now move to bottom right of the MSCONFIG window and click on the 'OK' button. Now the window will close, but next time you Restart/Start your computer it will be in Safe Mode (font will different, and it will say 'Safe Mode' at the four corners of the screen).
Aug 30, 2012 | HP Pavillion s7420n PC Desktop
Not able to start windows normally the page keeps on toggling and a black screen appears n goes :(
On boot-up press the F8 button which would bring up a screen. Select Safe Mode and then press ENTER... on the next screen select the Operating system and press ENTER. The screen will scroll rapid fast upwards and stop at a point for a few seconds. Then the screen with windows will appear with SAFE MODE written on the four corners. It will also ask you whether you want to run windows in safe mode. Choose YES. Now click start --all programmes-assessories-system tools- restore point. From there choose a restore point where the system was working properly and continue with the prompts. The system will restore your sytem after it automatically restarts. Hope it solves,. Else load a fresh OS.
Dec 30, 2010 | Computers & Internet
My monitor shows image immediately when switched on but just as soon the image appears the screen of the monitor goes dark after that need to off/on the power switch three to four times before the image...
Please restart your computer and tap the F8 key as soon as you see something on the screen. You should get the advanced boot menu. Select Safe Mode from the list.
Let me know if you were able to boot to safe mode.
Jun 18, 2010 | Dell E193FP 19" LCD Monitor
When booting up after the logo the computer goes to black screen. There are no beeps at start up. When starting in safemode it stays with black screen with the safe mode written in the corners
In safe mode try pressing ctrl+alt+del, then go to task manager-->applications-->New task, then type: explorer.exe Now your desktop should appear. you could also try running: msconfig In the same way, and see wether explorer.exe is still in the startup. Adding it again will permanently solve your problem. I hope this helps, Yannick.
Jun 13, 2009 | Dell Dimension 4400 PC Desktop
Computer only displays vertical lines and pink background.
Most likely an issue with the Video Card or Video driver.
* Boot to safe mode by tapping F8 while starting up the computer. Selected safe mode with the keyboard and hit enter. Login to your user account. You should see the words “Safe Mode” on all four corners,
* Open device manager – Right click “My Computer” – Select “Manage” – Selected device manager from the left. Under display driver, you should see your vide card listed. Right click on it and select “Disable”.
Now restart your computer and if this resolves the issue, then the vide card may be at fault. You could also try updating the video driver.
Do let me know if you get this far.
Mar 01, 2009 | Dell Dimension 4600 PC Desktop
HP Pavilion a420n
You almost certainly have a virus. If you can't even get into safe mode the easiest way to fix it is remove the hard drive and back up any files on it with a different computer, then re-install Windows on the original drive.
You can try booting from your Windows XP installation disk and using the recovery console there to repair your installation. That's not too hard and I would say works 30% of the time.
Jan 01, 2009 | HP Pavilion a420n PC Desktop
try switching to only "SAFE MODE"
you may also try pressing alt+del+ctrl keys at once this should bring up the task manager. you may try to end some process which may be malfunctioning and this will help you to go to the desktop.
please rate the solution
My computer
Search the Internet for a password changer. There are several out there. One I've tried is It's a $60 hit, but worth it in my business.
Mar 27, 2008 | Dell Dimension 4600 PC Desktop
Compaq presario 5000 not booting up right.
Does the Compaq logo appear when you try to start the computer? Try pressing F10 several times after turning on the power. This should start the "recovery console", which will give you some options for restoring Windows. If the recovery console doesn't start up, there is a good possibility that your hard drive or power supply module may be defective. In that case, you will probably need professional assistance to diagnose the problem.
Mar 19, 2008 | Compaq Presario 5000 PC Desktop
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
