Question about Coleman Powermate Powermate 5000W Generator
Engine cuts out when hot - Coleman Powermate Powermate 5000W Generator
  • 98 Answers
Every generator has an auto-shut down system that turns the engine off when over heated..u can dislocate the wire coming out of the engine and into the on/off switch...and then it till never shut off unless u tell it to....
but be carefull!!!!!!!!!!!!!:when u dislocate it...u r turnning off the auto-shut down system...so if the engine over-heats.. it will not shut down...
if u have any further questions email me at sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
I have a 1999 1.6 Suzuki esteem that cuts out especially when the car gets to hot.
G16 engines, know them like back of hand sold 3.
restored 2, total overhauled 1 engine my hands.
1996+ are all G16b (the B means 16valve heads)
all are MPI injected x4.
all are MAF based EFI. all are. and can fail for this.
to (too) hot, what does that mean? we use a thermal gun to see too hot the 17year old dash gauge is a toy. and OLD.
or means when engine reaches normal 180F temperatures, it ......
cuts out
elaborate that, please.
parked , cold engine, hot engine, (not overheated)
driving , at all speeds all gears ,hills and flat.
cuts out means nothing much.
cuts out can be a minor hesitations to a full on bog,
does car have wide open throttle power,?
cuts out can mean total 12vdc power failure, with all lamps in car showing that or groups, going dead or dim.
if yes, the EFI will lose DC power too. and cut out.
is the CEL lamp glowing running,?
Check engine lamp. in cluster.
its not a panacea that light but can glow.
the panacea if possible is scanning the PCM using any OBD2 scan tool made. see if there are DTC errors.
many do not set the CEL glowing, CEL is mostly for SMOG tests
in USA> (we invented it here)
minor hesitations,
  1. old or bad fuel
  2. MAF dirty clean it with maf cleaner (CRC) 6" afar. no close.
  3. o2 dead, unplug it see if symtoms go away. front 02.
  4. air leaks anywhere on the main air induction pipe MAF to TB will cause lean hesitations, (makes MAF lie)
  5. low fuel pressure. (a tool finds this, ask)
  6. dead maf, or ECU in limphome mode, scan it.
Mar 09, 2017 | 1999 Suzuki Esteem
Aeon Mini Kolt 50cc - cuts out when engine gets hot. What is wrong?
Check the compression on your engine take that off clean the valves is not much to an engine like that the engines cut down when it gets hot so it doesn't seize up make sure he got oil added to could be the O-rings but the compression tests would tell you that is not the race I checked the valves
Feb 14, 2015 | Motorcycles
I have a 2004 polaris sportsman 500 when it gets hot it cuts off and back fires
Does the cooling fan ever run when the engine is hot? If not, you may have a problem with the fan thermostat.
For the record, spray carburetor cleaner does no good if it's sprayed on the outside of the carburetor with the engine running. That's not what it's for.
Jul 29, 2014 | Polaris 2004 Sportsman 500 H.O
Engine cut out while drive
This sounds like it could be the coil needs replacing this is typical of coil problem. Hope this helps Best wishes, Malcolm Campbell.
Jun 20, 2017 | Vauxhall Astra Cars & Trucks
Cuts off when i stop then also igles to high pulls hills without even putting my foot on the gas
double posted. and still no engine temperature stated.
is engine hot or cold, back up one post and read.
what does cuts off mean, (engine stalls?) or power cuts.
add a word to the front of cuts, please. (a noun)
Dec 31, 2013 | 1999 Honda Passport
Car wont start when hot
Mr. Nicolas I have read your problem and saw that you have problem on hot start and cuts out. I will give you two advices. 1. Have you ever cleaned the throttle body on the engine? If not You must do it as that it is the reason of cutting out. 2. Check having help when the car starts if you have strong spark or fuel is not cutting off. Last thing I personally have the filing either you have tight valves even are hydraulic.
Aug 18, 2012 | Cars & Trucks
Starts but cuts off when engine gets hot
when it first dies check for spark or even better get a inline spark tester
Apr 06, 2012 | Garden
Machine cuts out due to getting hot
most vacuums have a heat resister in when they overheat they cut out, this is normally because they are full up, got a blockage or the filters need cleaning, suggestions are, clean filters, empty and check for blockage.
Jul 13, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
After the bike gets hot it cuts back really bad.
although you have had the carbs sync,i dont think the mixture settings are correct,the carbs are leaning out to much when the motor is hot
May 21, 2009 | 1997 kawasaki ZX-7R
When mower gets hot it cuts off crank back up run a min cut off
1 of 2 things happening
first change the fuel filter seams that the gas is vapourizing
If that does not fix it replace the engine coil as it heats up it is breaking down in voltage causing the engine to die
Apr 05, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Coleman Powermate Powermate 5000W Generator Logo
316 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
