Question about Apple 3-Year AppleCare for iBook/MacBook Series (MA519LLA) Mac Notebook
PowerBook Aluminum 17" not restarting after SLEEP MODE.
After being in the SLEEP MODE for awhile, my PowerBook Aluminum 17"  is not restarting... I have to plug in my adapter (65 watts) and wait a few  minutes.  Could this be due to a faulty PRAM battery?
I have also heard about the PMU board in other models... does the  Aluminum 17" have such a board which deals with charging the  battery and related functions.
  • 382 Answers
It does, but its not a fault, its a component. You may need to zap your pram or reset the pmu. when the power cable is plugged in, does the battery light flash on the bottom fo the machine confirming its charging? When you press power, does the caps lock key light up after being pressed? if your battery ( extenal ) is faulty, your machine should still power off the auxilary cable. the power cable bypasses the battery when plugged in. Do you keep youpower cable plugged in for extended times regularly, that kills batteries. make sure youre cycling properly.
Posted on Nov 17, 2007
Everytime I login to my Mac PowerBook G4 the screen shows logging in and then after about 30 seconds it goes back to login screen
FOR SOLVE THIS ..Starting your Mac in safe mode does the following: ... Start or restart your Mac, thenimmediately press and hold the Shift ... If your startup disk is encrypted with FileVault, you might be asked to log in twice: once to unlock the startup disk, ... If the issue comes back, you might have incompatible login items. 1 800 726 0294 Apple Support Number Mac Technical Support Help Apple Customer Support Number 1 800 726 0294 Mac Help USA APPLE SUPPORT NUMBER
Sep 09, 2017 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My apple powerbook display is just showing blank. I had turned the powerbook G4 and when I went to restart it the display would not show anything. I can hear the startup sound but nothing on the screen....
Just remove ur CMOS battery and harddisk connection from motherboard. And then try to restart it will give u a msg no boot device or OS found.. Now reboot and add the CMOS battery and harddisk on motherboard...
Apr 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple PowerBook G4 not coming out of sleep mode
the issue is bassically with Hard drive data cable.Still check the system by reinstalling the OS.or else replace the hdd data cable.the issue may get solve
Apr 13, 2010 | Apple PowerBook G4 Mac Notebook
Another waterlogged 12" PowerBook story
Sounds like you have done all you can. The hard drive should be ok and still work in an external case so you can transfer the data to a new machine. Good luck!
Feb 19, 2010 | Apple PowerBook G4 Mac Notebook
Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
Nov 02, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Restore CD
You don't need a "restore" cd.
You can just use any copy of Tiger.
Borrow one!
Jun 15, 2009 | Apple PowerBook G4 Mac Notebook
My powerbook g4 wont start
Your computer is booting into single user mode.
Try to boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot.
If so run disk utility from the cd and repair the disk as well as permissions.
If this is successful your computer "should" be repaired. If it still has problems booting, Use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Feb 22, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Goes to sleep
Pls check the power option settings in control panel.
Also pls check if the power management options for keyboard and mouse in device manager are enabled or not.
Pls try to create a new profile and check if the sleep mode is working in the new profile.
Pls try a System restore if the above steps don't work.
Dec 24, 2007 | HP Vs17 17" LCD Flat Panel Monitor
Apple 3-Year AppleCare for iBook/MacBook Series (MA519LLA) Mac Notebook Logo
107 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
