Question about Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT WML 520, water keeps on coming into the machine until it overflows, I can empty the machine by putting it on the drain setting, I have checked the pipes and pump and there is nothing blocking,
    Problem Solver:
  • 9 Answers
Sounds like a fault with the presure system
Posted on Jul 30, 2009
Hotpoint wml 540 spinning but water not draining
Hi
It seems likely that your pump is either blocked or faulty. It could also be a blocked or kinked drain hose.
You haven't nominated a model.
Good luck.
Nomess
Aug 30, 2014 | Hotpoint Washing Machines
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
My hotpoint few12 is emptying through top where you put powder But it is spinging ,Whats wrong with it
I think what was meant is that the water seems to overflow from the top side and so washes off the powder. This can be due to a improper setting or fault on the water level controller unit as it fails to detect and stop the water flows at a lower level.
Sep 29, 2011 | Hotpoint First Edition FEW12 Front Load...
Water keeps overflowing, dont know how to clean the filter or where it is .
hi, read about your problem. The filter is located at the bottom of the front of washer. If its not visible, remove the bottom kick panel. Three screws at bottom. Take a shallow pan and place under filter. Slowly turn counterclockwise and water will slowly start to come out. When pan is partially full, empty. Be sure to close filter before doing this. Keep up with this procedure until no more water comes out, then unscrew filter and remove and clean. Reinstall and put kickplate back on. Hope this helps.
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
Water overflowing and not cutting off.
The water overflowing problem could be one of three possible problems.
Water fill valve
Pressure level switch
Hose coming from the drum to the pressure switch.
Here is an easy way to check all three.
While the machine is on with water filling up quickly unplug. If water is still going in then replace the water filler valve. (In 20 years i only seen this happen once!)
Open the top panel so you can get to the water level switch. There will be a hose hookup to it.
Make sure there is water in the drum in this test. Disconnect the hose from the level switch. (you can turn off machine for this test) Blow thru the hose and notice if you hear bubbles going in the drum/water. If you do then good. If you dont then the problem was the hose came off the drum. Make sure it is securely attached because sometimes when it spins it might come off. If you do hear bubbles then blow again, pinch hose. Then reconnect to the pressure switch. You create air to the pressure switch. It should now shut the water off at the lowest setting. if it still doesnt shut off replace the pressure level switch. Sometimes i do this trick and it starts working.
this is alot of info, if you need clarifying let me know, i am slowly getting better explaining but will get better later thanks hope this was helpful
Mar 31, 2010 | Washing Machines
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
482 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
