Question about MinoltaFax 2600 Printer
CAUTION no paper(upper)
My machine
  • 63 Answers
Please insert some papers in the machine...
Posted on Jul 13, 2009
Mfc240 c gives unable to print see troubleshooting guide 51 I have tried all I know to do
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To solve this problem, please follow the steps listed below:
Note : images shown below are from the representative product and may differ from your Brother machine.
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
    Caution DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it.
    Be careful not to touch the feed roller.
  4. Remove the Paper Tray from the machine.
  5. Remove any remaining or jammed paper from the front of the machine.
  6. Look inside the machine, where the paper tray was installed and locate the white PE Actuator.
Caution Do not stand the machine on end. Ink may leak from the machine.
The PE Actuator looks like a 2 prong fork or tuning fork and is located near the rear center of the machine where the paper tray slides in. It is located between the 2 gray rollers.
  • If the White PE Actuator is in place, continue to Step 7.
  • If the White PE Actuator is missing, please contact Brother Customer Service from "Contact Us".
Using both hands, use the plastic tabs on both sides of machine to lift the flat-bed scanner until it locks securely into the open position.
  • Carefully examine areas 1 and 2 at the left and right hand ends of the platen area for paper scraps.
  • These scraps may have become saturated with ink and be difficult to see.
  • Use a flashlight if necessary to check thoroughly.
Aug 13, 2011 | Brother Office Equipment & Supplies
Cannot remove the paper jam
To clear the message Paper Jam from the display, follow the steps listed below:
NOTE: images shown below are from a representative product and may differ from your Brother machine.
STEP A. Check for and remove any jammed paper or foreign objects in the machine
  1. Unplug the Brother machine from the power outlet.
    Caution Before you unplug the machine from the power source, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  2. Lift the scanner cover using the plastic tabs or finger holds, located on the left and right side of the machine until it locks securely into the open position.
    Caution DO NOT touch the encoder strip. The encoder strip is a clear plastic strip in front of the white vinyl band (outlined in red as shown in the picture below). If the encoder gets markings or debris on its surface, it may cause other problems.
  3. Verify the location of the print head. The print head is a black square object, located behind the encoder strip. The print head moves from left to right.
  4. Move the print head to the middle using your fingers.
    Caution DO NOT touch the encoder strip (marked in red shown below).
  5. Check for and remove any ripped paper or a foreign object in the left corners or underneath the print head.
    Hint The ripped paper may be very small. Using a flashlight will help you to find the ripped paper.
  6. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper.
  7. Close the Jam Clear Cover. Make sure the cover is closed properly.
  8. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
  9. Remove the paper tray (1) from the machine.
  10. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
  11. Using your hand, lift the front of the machine approximately 6 inches off the surface.
  12. Look inside the tray areas roof of the machine and a row of black rollers will be aligned across. See picture below.
  13. Look in-between each of the black exit rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
  14. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
  15. Place the machine gently down onto the surface.
    • If no paper scraps were found inside the machine, please check the paper in the tray. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper in the tray must be replaced and continue to STEP 16.
    • If paper scraps were found and removed from the machine, continue to STEP 16.
  16. Put the paper tray back into the machine.
  17. Plug the power cord back into the power outlet.
    • If the LCD displays the date and time, go to STEP D.
    • If LCD displays the message "Paper Jam" go to STEP B.
- If the print head is on the right side:
  1. Plug the power cord back into the power outlet and wait for the machine to stop making noises.
  2. Press the Stop/Exit key for approximately 5 seconds until the print head moves to the middle.
  3. Unplug the machine from the power outlet.
    Caution Make sure to unplug the machine. The print head may move and injure your hand. Before you unplug the machine, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  4. Examine the right side of the machine where the print head had been positioned and underneath the print head and remove any pieces of ripped paper or foreign objects.
    Tweezers may be used with caution to remove paper scraps or the foreign objects.
  5. After confirm the paper scraps or the foreign objects in the right corners or underneath the print head, go to STEP 6.
Mar 10, 2011 | Brother MFC255CW All-in-One InkJet Printer
How do you remove a paper jam at the site where the paper exits the printer (causing an accordian-style fold)
Turn off and unplug the machine you can open the front door open the exit side where the paper exits out gently remove paper the issue is caused by the upper fuser claws on the fuser unit they are worn you will need to replace them or replace the fuser unit assembly as other internal parts in the fuser may also be worn like the rollers
This should be done by a trained certified engineer
WHEN YOU TURN OF MACHINE MAKE SURE TO OPEN DOORS AND WAIT A FEW HOURS SO THE FUSER AREA CAN COOL DOWN CAUTION THE FUSER AREA IS VERY HOT
Feb 10, 2011 | Canon imageCLASS D320 Digital Copier
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
HP Deskjet3845
To remove the jammed sheet of paper :
1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out. CAUTION! The paper may be covered with unfused toner, which can stain garments.
6. If you see no paper jammed under the cartridge, remove paper tray 1. The paper may not have fed all of the way into the printer.
7. Reinstall the paper tray and the toner cartridge.
8. Close the upper front door.
Mar 11, 2009 | HP Deskjet 3845 InkJet Printer
Coulnd't send a fax
I had the same problem and called canon helpline.
They said to unplug the machine from the mains, then take out the plastic guard where the paper tray is fitted. There is a lever just above the paper tray. Make sure that it is pressed up completely. Then reconnect to mains.
I tried it and it worked.
Dec 27, 2007 | Canon FAX-L1000 Plain Paper Laser
Paper jam
If the jammed sheet is entirely within the printer, remove the sheet as follows:
r_1.gif Make sure that the printer is turned off.
r_2.gif Open the printer cover by pressing the latch on the left side of the printer and lifting the cover up all the way.
r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Opening the printer cover exposes the fuser, which is marked CAUTION Hot Surface Avoid Contact. Be careful not to touch the fuser. If the printer has been in use, the fuser may be very hot.
hppe004.gif 1. CAUTION Hot Surface Avoid Contact
r_3.gif Remove the developer cartridge.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif When removing the developer cartridge, never touch the developing roller under the flap; otherwise, print quality may decline.
r_4.gif Remove the photoconductor unit.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Never touch the photoconductor unit's light-sensitive drum; otherwise, print quality may decline.
r_5.gif Remove the paper from the paper path.
r_space.gif r_note.gif Note: r_space.gif r_space.gif If paper is jammed at the fuser, grasp the bottom of the paper and pull it out.
r_6.gif Reinstall the photoconductor unit, and then the developer cartridge.
r_7.gif Close the printer cover.
r_8.gif Tap the edges of the stack of paper on a flat surface and carefully reload it into the MP tray. (Do not reload curled or wrinkled sheets.)
Printing automatically restarts from the page that jammed. If the Paper light stays on after removing all jammed paper, open and close the printer cover to clear the error.
Oct 16, 2007 | Lexmark X7170 All-In-One InkJet Printer
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
MinoltaFax 2600 Printer Logo
47 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
