Question about Panasonic KX-P3200 Matrix Printer
Print not aligned to left, is angling across page
  • 156 Answers
Remove cartridges and re-install. Then align cartridges. Hope this helps.
Posted on Jul 13, 2009
It does not print alignment test page can you email me one ?
How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
Oct 13, 2011 | Dell 926 All-In-One InkJet Printer
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Test page printing at the time of printer powered on
s.gif Solution minimtop.gif The product aligns the print cartridges every time that print cartridges are installed or replaced to ensure the highest-quality prints. The alignment page will continue to print every time that the product is turned on or off until the alignment process is completed. NOTE: If you remove and install the same print cartridge, the unit will NOT align the print cartridges. The unit remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. Follow the steps below, in the order presented, to correctly complete a print cartridge alignment. s.gif Step one: Remove the print cartridges minimtop.gif
  1. If the On/Resume button is not lit, press the On/Resume button to turn the product on. Figure 1: Press the On/Resume button to turn the product on c00316907.gif
  2. Make sure the paper tray is down and there is letter or A4 unused plain white paper loaded in the paper tray.
  3. Lower the access door until it stops. Figure 2: Lower the access door c00316908.gif Make sure the print carriage moves to the center. Figure 3: Print carriage in the center of the printer c00316909.gif
  4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it. Figure 4: The print carriage c00316910.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black print cartridge, remove the print cartridge from the slot on the right.
    Figure 5: The print cartridges in the proper position c00316912.gif 1 - Tri-color print cartridge 2 - Black print cartridge
  5. Pull the print cartridge toward you out of its slot.
s.gif Step two: Install the new print cartridge minimtop.gif
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward at a slight upward angle into the empty slot. Using your index finger, push the print cartridge forward until it clicks into place. Figure 7: Insert the print cartridge c00316911.gif
  3. Close the access door.
s.gif Step three: Align the print cartridges minimtop.gif If you are installing a new print cartridge, the product begins to print a print cartridge alignment sheet. This may take a few minutes.
  1. Lift the lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass. Figure 8: Place the alignment page face down c00316913.gif
  3. Close the lid.
  4. Press the Scan button.
  5. The On/Resume light will blink during the alignment process.
  6. After the On/Resume light stops blinking, alignment is complete.
Feb 26, 2009 | HP PSC 1410 All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
How do you change an ink cartridge on a HP officejet 5510 printer?
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Aug 11, 2008 | Office Equipment & Supplies
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
      NOTE: The black cartridge is on the right side of the print carriage.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
Aug 27, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Panasonic KX-P3200 Matrix Printer Logo
117 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
