Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Samsung rsh1dtmh has stopped dispensing water. water is entering the unit ok
SOURCE: American fridge freezer - sansumg rsh1dtmh
I had the same problem. There is a circuit board on the very top of the fridge/freezer. There is a 5amp quick blow fuse on there. Sounds like that has blown. Mine did for performing the same function. replaced it and all is good.
Posted on Feb 20, 2008
tborn6
  • 700 Answers
SOURCE: water filter holder
http://downloadcenter.samsung.com/content/UM/200709/20070915083700656_DA99-01583A-EN.pdf this is the link for your manual, look at page 38 and that shows where your filter is located on the unit. I personally have bypassed my filter and installed a higher quality inline filter in the back of the refrigerator my self. The first reason being is that I for one had the inline filter on my older one and the second is that i have several still ready for replacing. and third they are less exspensive for me to but. GOOD lUCK
Posted on Jan 09, 2009
asnowman
  • 788 Answers
SOURCE: Do I need to install water filter? Is it critical?
The water filter is your call. This can remove sediment and some odors. If you have good water where you live, it should not be a big deal. The only thing is that it is a hassle to get behind the fridge to replace the filter. I have seen man people install their fridge without a filter and be very happy with the performance of the system. Not Critical, but some would say it is.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
Posted on May 03, 2009
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
  • 3 Answers
SOURCE: I have a samsung fridge
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Posted on May 21, 2011
I have Samsung rfridgewith freezer on bottom. We replaced the the ice maker but but now it makes ice just won't dispense
try defrosting the ice dispenser portion of the unit, it might have ice buildup stopping the auger from functioning
Jul 13, 2017 | Samsung Refrigerators
Samsung Refrigerator water dispenser does not work? Ice maker works
The electrically operated valve that opens when you attempt to get water is probably bad. This unit may have one unit with two valves. One each for the ice maker and water dispenser. This valve unit will be in the back of the refrigerator and have a copper or plastic supply line from your house. This line will be "live" so be sure and find and close the valve attached to your house's water supply.
Mar 02, 2015 | Samsung Refrigerators
OUR RFA4287HSAWP Samsung has the same problem mentioned here. It suddenly stopped dispensing ice with only water dispensing from both levers. I tried the ooparts number listed but of course was told i
If you can, send me the model and serial number from your unit... you can also snap a picture of the model/serial tag and please send it to me and i will help you solve this issue... the picture will give me a heads up to any updates for your unit... I think we are looking at a control issue but i want to be sure..... Ken Hawk...... Samsung support
Feb 12, 2015 | Samsung RF265AA Bottom Freezer French Door...
Water stopped coming out of door dispenser
A few videos about refrigerator water dispensers.
Might not be exactly the same as yours.
Samsung won dispense water YouTube
Oct 05, 2014 | Samsung RF4287HA
Water entering Dispensor and will not stop
check the water in celanoid may not be closing if not check pressure pipe from the drum to air switch
Mar 01, 2014 | LG WM2050C Front Load Washer
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
Water does not put water in tray drinking dispenser works good what can be the problem water supply hose is clear thanks
First check the water flow.Is the water flow running.If the water flow is blocked then no water will enter the dispenser.If water is running properly but its not entering the water dispenser then check the water tube,is it kinked or got loose or got blocked.But if water is running ok,and water tube is proper and not blocked or kinked.Also connected properly to its hose Then the possibility is water valve,this is at the back of the ice maker unit.There is a twin valve,which lets the water enter the ice dispenser and water dispensing unit.But if the valve is blocked from one side or faulty then it will not let the water to get dispensed.Also in some cases the ice gets clogged in the water fill tube and this creates the problem.If there is ice frost problem then you can use hair dryer to melt the ice collected in the water fill tube.But take care you unplug the unit from main power outlet before doing this.Its for safety reasons. If the valve is faulty then it has to be replaced.And you can get required parts from online sites like,sears parts direct or from repairclinic.com --------- This will help.Thanks.Helpmech.
Dec 19, 2010 | Frigidaire FRS23R4A Side by Side...
Water filter holder
Jan 09, 2009 | Samsung Refrigerators
this samsung fridge freezer diy channel may help ckick here
also check this video ....http://www.youtube.com/profile?feature=iv&user=SamsungFridgeFreezer&annotation_id=annotation_526429
Dec 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
738 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
