Question about Apple iMac All-in-one - 2.66GHz Intel Core 2 Duo, 2GB DDR2, 320GB SATA HD, SuperDrive 8x
Disk utility won't recognize that there is a superdrive neither does system profiler there is a dvd in the imac, which i watched about 12 hours ago. usual fixes (left click restart) won't do the trick. the dvd is a rental!! due in but a few hours. PLEASE HELP! thx i have the 09 imac 20"
    Problem Solver:
  • 5 Answers
They are a few thing to try althoguht you may have already tried them;
Pram and PMU reset -
First turn off the iMac, once turned off unplug everything from the IMac and physicallly unplug it from the wall, wait about 5 mins at this point, then just plug in the very basics (keyboard + mouse) - this is the PMU or power management unit aspect of this - the next step is a PRAM or paramiter RAM reset
To do this hold down the apple + alt + p + r key on your keyboard just after you turn on the iMac, and keep these held down, you should hear it chime as normal, now if you keep holding down the keys you shoud here it chime again, keep the keys pressed down till you have heard 4 chimes in total.
After that is done let go off the keys and the iMac should restart as normal - can you eject the disk now?
Sadly System profiler is normally very effective at picking up hardware that is installed in your Mac, The fact that it is not brining up anything would suggest that the super drive may be faulty or somehow disconnected, if you try the above and it does not work then i would suggest you call a AARC or apple authorised repair center and have the S/N: Serial number of your Mac ready - you can find your local repair center on the Apple website - for example the closes repair center to me would be Jigsaw Solutions LTD (www.jigsaw24.com) who are the UK's largest retailer of Apple abode and Quark.
I hope the above is helpful and that you do not need to contact an apple authorised repaird center!
Posted on Jul 14, 2009
Imac wont recognize my new internal hard drive
Yes, rem it is iMac, it has to be formatted for iMac, sorry there is a way, if you have alternative access, search box and type in formatting new had for iMac. Good luck.
Feb 08, 2013 | Apple iMac G5 Desktop
IMac dvd don't work
Need for info?
Does it accept the DVD but not mount it?
Does it not burn DVDs?
Check your DVD settings in system preferences.
Jan 19, 2013 | Apple 27" iMac Intel Core i7 2.93GHz, 8GB...
When I turn on the computer it takes a while to boot up, and when it does it stays idle for 10 seconds or so then shuts off?
Sounds like there may be a problem with your OS X.
You will need to boot from your OS X DVD and run your Disk Utility to do a repair on your operating system.
To do this, start your iMac and pop in your DVD. Once you hear the boot up sound, hold the Option/Alt key. You will be given the option to choose between your hard drive boot up and DVD boot up, so choose the DVD. It'll take a while longer to load than usual as you're booting from a DVD, but once your Mac has booted up, use Spotlight (Apple + Space, type "Disk Utility") to load up your Disk Utility program. Once you've got that open, select your hard drive on the left and click "Repair Disk Permissions" and then click "Repair Disk."
Once you're done, reboot and your Mac should be working good as new.
Mar 25, 2011 | Apple iMac Desktop
Where is serial number located on imac i7?
Under the Apple menu select "About this Mac", then click "More Info" to open the System Profiler. In the hardware overview you will find your serial number.
Feb 06, 2011 | Apple 27" iMac Intel Core i7 2.93GHz, 8GB...
I have a Que M3 hard drive 80GB,which is not recognized on Imac.
Few thoughts
1. Go to System Profiler (see in Applications then Utilities) and check whether (dependent upon whether it is USB or Firewire) the drive is showing up
2. Have you checked whether the cable is okay, have you got a spare cable.
3. Change the usb port on the imac that you are using (could be damaged)
Good luck
Oct 20, 2009 | D-Link Computers & Internet
How do I replace a dvd superdrive in a 24 inch imac
Hi, I have an iMac 20", its not 2 years old, and the dvd got stack inside, it won't come out, how in the world can I fix that problem? how can I change the dvd burner?.
Is there anyone who could help me hout?
thanks
Jose
Sep 22, 2009 | Apple iMac 24" Desktop
Folder with a question mark at startup
That means the hard drive has gone out or the controller for it. You could take a chance and replace the hard drive or if you have a the warranty on the unit have apple fix it.
Jul 30, 2009 | Apple 13.3 MacBook Intel Core 2 Duo...
Mac book will not turn on.
A flashing folder at startup means that the Mac doesn't recognize your system. This can be either a hardware or software problem. The hardware problem would be the hard drive, and the software the OS.
So these are the steps you should proceed: 1) Check your hard disk by using your install DVD (press the c key at startup), choose your language, go to the utilities menu and hit Disk utility. go to SOS tab and select your hard drive on the left. Click "repair volume" and check what happens.
2) reboot, if it does not recognize the system again, reinstall it using the "archive-install" option
May 29, 2009 | Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz...
''imac g4 does not see dvd drive after Xferring files and setting
when booting in os x after the first boot chime immediately hold down keys <apple,option,o,f> all at the same time and allow computer to boot to open firmware once there type "reset-nvram" exactly like that but without quotation marks and press enter once it returns to command prompt type "reset-all"and press enter (you must have the "-" in between the commands) the computer should restart if not when the command prompt returns type "reboot" and hit enter ..... also you can check the drive status by going to "system profiler" in apple drop down menu--->about this mac-->more info or applications folder-->utilities folder--->system profiler then selct disk burning under hardware in the list on the left
Mar 18, 2009 | Apple iMac G4 Desktop
Stuck dvd in superdrive
When you turn the computer on, press and hold the mouse button and keep holding it until the disk pops out.
Nov 30, 2008 | Apple iMac G4 Desktop
Apple iMac All-in-one - 2.66GHz Intel Core 2 Duo, 2GB DDR2, 320GB SATA HD, SuperDrive 8x  Logo
399 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
