Question about Symbol LS 2208 Barcode Scanner - P/N LS2208-1AZR0800S (LS22081AZR0800S)
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How to run it correctly? Best regards Michal
    Scholar:
  • 74 Answers
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Posted on Jul 13, 2009
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 | Computers & Internet
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Mar 24, 2017 | Honeywell Office Equipment & Supplies
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Hi, can ls2208 scan a memorex 9840 tape bar code label? Understand that in conform to the Code 39 Barcode Specification. It doesnt seem to work. thank you.
Hello khlai. The quick answer to your question is: Yes. An LS2208 can decode (read) code 39 barcodes. However, since you are reading a barcode on a tape, I would predict that the symbology is actually 'Trioptic Code 39". Trioptic Code 39 is a variant of standard Code 39 that is used for marking computer/tape cartridges. I've uploaded the LS2208 manual to my company's website for you. Just follow these instructions and you'll be right as rain.
  1. Go to www.shiftintoblue.com/resources/ls2208_manual.pdf and save the manual to your computer (or print directly from the web.)
  2. Go to and print page 194 (12-28) that contains the Trioptic Code 39 barcodes.
  3. Take the printed page and scan the barcode labeled "Enable Trioptic Code 39".
Then you're all done! That should fix the problem. If you have any other problems, feel free to send me a message or email me. I hope this helps. Good luck!
Jan 05, 2010 | Symbol LS2208 Handheld
When we scan it will read factories bar codes but no other bar codes does anyone know how to fix this problem?
What software are you using with the scanners as it can be configured to only read codses beginning in a certain number
Aug 07, 2009 | Symbol LS2208 Handheld
Program Symbol LS2208 scanner
Hello this requires advanced data formatting which you will have to scan some bar codes to program it. If you give me your email I can send the codes to you.
Jun 19, 2009 | Symbol LS2208-7AZK0100S Handheld
I have this situations: my system don't read any code begining with 0, please need this configuration for symbol LS2208. Thank you.
Your scanner must have been delivered with a "Quick Start Guide".
All you need to do is to scan the following barcodes from thar Guide:
1.Set Defaults
2. Scan Options
3.<Data><Suffix>
4.Enter
5.The barecode for whatever type of connection you use (RS232, Keyboard, etc.)
Jan 30, 2009 | Symbol LS2208 Handheld
Symbol LS2208 barcode reader no data to screen
Just because it has a DB9 does not mean it is a direct connection. Many Bar code scanners have the DB9 connecting to a interface box and the interface box connects to the PC. If it is really a rs-232 scanner then you need to configure your serial port to the proper settings specified by symbol. But I am confident that this unit is missing the interface box.
Jun 27, 2007 | Symbol LS2208-7AZK0100S Handheld
Computers & Internet Logo
547 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
