Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
External hard drive shown as portable disk and does not work
I have Toshiba external USB mini hard drive, which was working normally almost half a year. Now when I plug it in the PC either does not see it or it is being recognized as portable hard drive (Sunplus USB2SATA bridge USB Device). But still I can not open the device. I tried connecting it to different usb´s, very few time it read for few minutes, so at least I was able to copy few data, but then it stops again. Please help. Petra
  • pet_les Jul 13, 2009
    Hi, I still have varranty, already spoke to the servis and they are willing to exchange it. But I mostly need the data. I was hoping that there is going to be some easier solution than opening it. :-)
    I might not be able to put it all back together in the end. :D After all I am only a woman. :-)
    Thanks for the info.
    Petra
  • 390 Answers
Hi
i think the hard drive is ageing,
if you are past warranty try to open up the casing and try to see if you can connect the HDD to connect individually else where (like with another casing or Laptop PC) if still not connecting then the problem is with the HDD
else the problem may be with the casing
cheers
pls rate if this was any help
Posted on Jul 13, 2009
  • 63 Answers
Please consult with the customer care....
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
My toshiba 250gb external hard drive doesnt show in my computer (xp) but it is in device manager?
Click Start
Right-mouse click My Computer
Click Manage
Expand the Storage branch
Click Disk Management
Click Disk Management (local)
Click to create a partition on the drive, and to assign a drive-letter.
Oct 27, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
External hard drive won't connect to computer
first of all you should try it on deferent pc , if its ok then thatleads us to insufficient power provided through usb ports , try usingback usb ports not the ON-front, and if the problem still try usingdual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.htmland if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changedif you cant find a similar one you may buy a new empty cage
Mar 22, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Toshiba 120 GB USB 2.0
check if you have another drive which has the same alphabet as your external drive, if so then go to disk management and change the name of the disk.
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Maxtor external portable hard drive. P/N 9NX2DC-500
first it has to be formated to work with it, use manage by right click on my computer then select disk managment from left pane
Oct 27, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Code 10. The device cannot start
Go to, Start > Settings > Control Panel > Administrative Tools > Computer Management > Disk Management. See if the drive starts under Disk Management.
I sounds like the drive enclosure is shot. You may need just a case. Click this link: http://cgi.ebay.com/USB-2-0-2-5-EXTERNAL-HARD-DRIVE-ENCLOSURE-CASE-NEW_W0QQitemZ120099119775QQcmdZViewItem?hash=item120099119775
Or you can get the whole unit and swap out the drives so you won't lose your data.
http://cgi.ebay.com/NEW-MAXTOR-ONETOUCH-4-MINI-120GB-HARD-DRIVE-USB_W0QQitemZ160267138312QQcmdZViewItem?hash=item160267138312&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Aug 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Plug and play? doubtful.
Is the drive partitioned and formatted already?
Does it work on another computer?
Is the drive powered via the usb cable, or does it have an adapter?
Do you have any networked drives on this computer?
When it is connected on your computer,
click Start
right click Computer
click Manage
double click Storage
double click Disk Management
Is it in the list of drives in the lower half of the window?
Mar 14, 2008 | Toshiba 120GB USB 2.0 Portable External...
Open Questions:
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
1,355 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
