Question about Canon imageRUNNER 2000 Copier
Refretion key of canan IR2000 copier
My copier has disply an error of E000 how can i solve the problem and how can i reset(refretion) the copier
    Problem Solver:
  • 19 Answers
Do you have to change the film unit and you can't to reset this code.
Posted on Jul 28, 2009
Hie, i have a problem with two printers, the canon ir2000 and the canon ir2010 it first gave me the error E000 message i resseted it then it now gives me the "check printer cover" message, what...
Error E000
Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000
Error "check printer cover"
I think your problem is fairly simple if you have technical background. just check door compartment carefully there is a plastic part which presses the sensor switch or cover the optical sensor may be broken.
If not, then take a digital meter and ground the common probe and positive probe touch to the related sensor.there are two type sensor 1) switch type 2)optical, that they use.
If the switch type is used, when door is open voltage is 0,door close voltage is 5 volt although this may be reversed.
In the optical sensor case, one side is diode that is on 1.5 volt and other side photo transistor.
connect probe to trs side to collector or emitter depending on what biasing they use, then open door and see if the emitter goes high or low, repeat in door close position also if it goes properly high and low, if not then some other part is faulty.
If you are not sure how to do this then call in a technician
Jul 26, 2011 | Canon Office Equipment & Supplies
I have canon ir2000 photocopier machine and i t is showing e354
Canon IR 2000 copier is showing System Error E000
From my searches online the first course of action seems to be resetting the printer in service mode.
I attempted to clear it in service mode:
1. Press ADDITIONAL FUNCTIONS, #
2. Go to #7 Printer and press OK
3. Go to #4 Printer Reset and press OK
4. Yes = ( > )
However, when I press the yes (>) nothing happens.
Does anyone know why this is not working?
Apr 15, 2011 | Canon ImageRunner 1600 Copier
My canon ir2000 copier says: System Error E000!!! what can i do for this kind of error. my exact copier model is Canon IR2000. sorry for product identification i didn't get my model from the list thus why...
That means that you have fixing error.Try next:
press MENU and #, with cursors go to clear, press ok, select err or all and ok.
If the problem was only fluctuaction in temperature the machine would work normally.
If not call service, because you have problem with heating lamp, or thermistors, or...
hope that helped
May 13, 2010 | Canon iR 1600 Laser Photo Printer
''System error E000''
the problem related Image Processor PCB
you will need to restart the machine.
May 13, 2009 | Canon Office Equipment & Supplies
System error E000 in conon ir2000
Sir,
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Thanks
Good Luck
Apr 28, 2009 | Canon imageRUNNER 2000 Copier
I have a cannon ir2000 and it's giving : system eroor e000 can i know what's the solution please ?
hi
first try to reset by doing this * 28 * then reset ok. if the same thing happen you must replace fixing assy. : (
Dec 15, 2008 | Canon imageCLASS D320 Digital Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER 2000 Copier Logo
117 people viewed this question
old marine
old marine
