Question about Toshiba Satellite A100-S8111TD Notebook
Laptop screen does not show desktop and remains blank after boot.
I own Toshiba Satellite A-100 , it boots fine but after welcome note of Windows Vista ,screen remains dark and I can't see my desktop.
  • 85 Answers
Re: Laptop screen does not show desktop and remains blank...
This is a driver loading problem, where the OS is trying to load a communication layer for a device which then fails and drives the machine into a steady loop. Unplug all devices and cards from the machine and reboot. If this works normally, you have a device driver problem with one of the things you have plugged in and need to troubleshoot it from there. If it still hangs, I bet you have a bad video driver (or USB driver). Reboot to SAFE MODE and then try changing the drivers for video and USB (and then motherboard drivers if any) to Microsoft standard distribution drivers until you get a normal boot and know which device/driver set are causing the trouble. Then hunt up updated drivers for that device on the web. Vista especially is very driver buggy.
If all else fails, reinstall the operating system using the REPAIR option.
Good luck...
Posted on Nov 16, 2007
0 characters
3 Points
Toshiba Satellite Ultrabook U945-ST4N02 Windows 8,
Check with the moniter by connecting the VGA Cable. is there any display on moniter if yes then laptop;s screen faulty otherwise motherboard issue.
Oct 11, 2013 | PC Laptops
Toshiba satellite m45-s169 will not boot windows
Windows is corrupted or the hard drive has issues, if you have a cd installation disc try a fresh install, if no change! the hardware needs to be checked for possible replacement.
Apr 14, 2012 | Toshiba Satellite M45-S169 Notebook
The laptop will not boot up. Screen is blank with only the mouse icon showing.
Try booting your laptop in safe mode to see if your OS boots up.
Feb 28, 2011 | Toshiba Satellite U305-S5097 Notebook
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
May 16, 2010 | Toshiba Satellite L305D-S5874 Laptop
Toshiba L350 series laptop shows "windows failed to start" screen when booting up & goes to a completely blank screen afterwards. Tried using recovery cd & can't get C prompt to come up. Need...
Shut down the laptop, make sure that no light is lit up. Before booting it back up, press and hold the F12 button. It will lead you to boot options. Open up your DVD drive and insert Disc 1 of recovery then make sure you select the ODD or the dvd drive to boot up. This will start the recovery process.
Other models has Icons for boot options. Make sure you select the single disc option to boot the ODD.
Hope this helps.
Dec 20, 2009 | Toshiba Satellite L350-ST3701 Notebook
Toshiba satellite A100 Monitor problem
LCD issue it needs tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Laptop Screen is Blank
there is a hole on the back usually goldish inside take a pen push it in there hold for a couple seconds and press the power button
Jan 26, 2008 | Toshiba Satellite M35X-S349 Notebook
Windows boots up but the screen is completely blank
First, try booting into safe mode and un-installing all the Java Runtime Environments (JREs). Reboot after un-installing all the JREs. If prompted to reboot after one install, click no until all JREs have been un-installed. Now, what do you mean by a blank screen? Do you see the Windows XP screen as it initially boots up, but then the screen just goes black? If this is the case, then your video settings probably got wedged. Perform the following steps to reset the video settings back to the default. 1) Boot the laptop into safe mode. Boot into safe mode with networking support if possible. This can be done by tapping the F8 key as the computer first turns on. 2) Once you are at the Desktop, right click on My Computer and select Manage. 3) In the window that appears, select Device Manager from the menu on the left. 4) Find Display Adapters on the right and click the plus sign. This will list the video adapter that you have. NOTE: WRITE this down EXACTLY. You may need to go and get drivers for this. Seeing this is an older model, I doubt you'll need it, but better to be safe then sorry. 5) Go to your manufacturers support web site and download these drivers. You may not need them, but better to be safe then sorry. NOTE: Skip step 5 if you did not boot with network support or cannot get to the Internet. This can be done from normal mode. 6) Right click on the display adpater and choose un-install. Hit OK on the window that appears and reboot the machine when the process is done. 7) The machine will take longer than usual to boot, as Windows XP is re-discovering the video adapter and resetting everything to the defaults. When it is done booting, the screen may look weird since the settings are now the defaults. You can the set them to what you want by right clicking on the desktop and selecting properties. Then go to the settings tab. 8) IF it did not re-discover the video adapter (this can be confirmed through the device manager), then go ahead and install the drivers. Windows Update will most likely also have the drivers.
Sep 13, 2006 | Toshiba A75-S125 Satellite Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
123 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
