Question about Electrolux 23 in. ESL6114 Built-in Dishwasher
No hot water during wash - Electrolux 23 in. ESL6114 Built-in Dishwasher
    President:
  • 942 Answers
Hi..
If your washer have no hot water during wash, you need to check this:
  • Check that the water supply valves are turned on
  • Inspect the water supply hoses for kinks
  • Check the filter screen
  • Test the water level switch
  • Test the water temperature switch
  • Test the timer control
  • Test the water inlet valve
Hope it may helpful
Regards
PCmania
Posted on Jul 13, 2009
remove the hot water pipe from the washing machine and check whether there is a blockage at the inlet of the pipe. also check whether the hot water is coming from the tap.
Apr 24, 2016 | Washing Machines
No Full Hot Water wash
the hot selection only tells the machine to turn on the house hot water to the machine
if you have it on warm , then both taps will be working
if you want a really hot water wash , there will be an element in the tub to bring it to temp
naturally an energy saver will not waste money heating hot water
Sep 15, 2017 | Washing Machines
Unit will not switch from hot to cold
check hoses connections- hot to hot and cold to cold at both ends. If not ok, check if you are setting the machine correctly. These days washing in cold water is effective.
Dec 08, 2013 | LG WM2101H Front Load Washer
No hot water coming in during the wash cycle.
Hello Stephen Foster - Based on the symptoms you are describing, typically, the unit could possibly have a faulty timer, temperature sensor or water valve. Confirm that the holes are properly connected. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. However, if the issue persists, it is always a good idea to have a service tech properly diagnose your appliance.
Apr 15, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Washer only washes with hot water
consult your owner manual about you are unsure about if the machine is acting anormally
Some machines, is running hot water during cycles, other cold water during cycles.
God bless you
Jul 18, 2012 | Washing Machines
The water isn't getting hot
If the water to your kitchen tap is above 120 to around 145 your machine is getting hot water. If not your need to adjust your hot water heater.
It is fine to open the DW door during the wash cycle. The unit will hold the wash cycle. Open the door during the start of the wash cycle (not rinse) and see it the dispenser door is open. If not it could be the timer is not sending the proper signal to the dispenser on when to open. This would be a timer issue and you would want to replace the timer. I doubt that this is it but it is possible.
Hope this helps.
Mar 22, 2010 | GE Dishwashers
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
High pitched noise during hot water only
This problem is usually caused by LOW water pressure going in the washer.
1. Remove hot water hose and flush all debree from water line.
2. Change water filters and you'll be good to go.
GOOD LUCK!
Aug 30, 2009 | LG WM-2277HW Front Load Washer
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
When temp is set on hot water--hot water shuts off & cold water comes out
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Mar 16, 2008 | Washing Machines
Electrolux 23 in. ESL6114 Built-in Dishwasher Logo
454 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
