Question about General Electric Chest Freezer FCM5SU
Its only freezing round the top not the bottom?
  • 736 Answers
When you have a slow leak in a refrigeration system .. there will come a time when there is not enough refrigerant to service the entire "evaporator" (cold coil) .. the symptoms would be: extra cold areas in the first part of the cooling coil and no or little cooling in the rest.
if its an older system then it likely uses R22 refrigerant (being phased out) .. newer ones use R134a .(also now causing some environmental concerns) . the system is normally sealed so the refrigerant has to be added through an "add on valve" (saddle valve) .. a dryer unit is often added to make sure no moisture has gotten into the system .. you need gages and special know how to do all this safely .. you should also locate and repair the small leak ..(soap bubbles or a special sniffer can be used). if its an older unit then it might be better to just replace it since newer ones are considerably more efficient ..
of course make sure that the external "concenser" coils are clean .. if those are clogged, cooling capacity and efficiency go way down .. even so its unlikely to cause yoiur symptoms ..
Posted on Jul 13, 2009
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Freezer will not shut off some things frozen, bread and ice cream soft
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Dec 28, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Top half does not freeze
There is a fan behind the back wall of the freezer about 1/2 way up from the bottom, you should be able to hear this running when the freezer is on. If you do not hear this then you need a new evaporator fan motor.
If you hear the fan run then you most likely have a problem with the automatic defrost cycle that would most likely be the heat element that is located just below the coils inside the freezer behind the panel.
Apr 21, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Freezer not freezing at the top. But tray at the bottom freezes.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 14, 2010 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
My freezer is freezing at the bottom but is not at
Short on refrigerant would be a good starting point, pressure temp relationship should be tested by an opperative.
Jun 27, 2009 | Hoover 9.9 cu. ft. / 280 liter Upright...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Jan 15, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
General Electric Chest Freezer FCM5SU Logo
148 people viewed this question
Top GE Freezers Experts
christian nielsen
John Tripp
John Tripp
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
