Question about Kenwood KDC-138 FM / AM Receiver
I hooked up my speakers when I moved reciever the wires shorted it out and now the stand by light is on and reciever does not work
  • 736 Answers
Almost all systems have protection from short circuits but still some fail .. a few have fuses for each speaker but most have circuit protection such that failure of any of the power amplifiers (one for each channel) will cause shutdown (standby) of the entire unit .. rather than damaging your speakers with a large DC voltage that might be present in the fault mode ..the speakers are often isolated using relays to avoid damaging them .. the solution would be to replace the defective power module (or transistors in older or higher power systems) .. often the damaged amp will also open one or more balasting resistors (low value like 0.1 ohm) ..
your system may still output through the low level RCA output jacks ... you could connect those to an external amplifier .. since your amp is indicating a fault conditon, its not a good idea to leave speakers hooked directly up to it until its repaired ..
Posted on Jul 13, 2009
  • 137 Answers
First fined the short on the wires then replace the fuse o the unit if that does not work then the unit needs to be replaced
Pioneer SX-315 Speaker Problem
The bump may have broken or disconnected speaker wires.
May 17, 2017 | Pioneer SX-315
The word Protected shows up on the reciever! I tried to clean out the bad grease on the Volume control. The remote got so sluggfsh it would hardly move.
Protected is usually the unit has partially shut down to prevent further damage or burning up. The high power amplifier section is shorted or the speaker wires are shorting, including speakers. The speaker wires can be checked and eliminated as a problem, where frayed wires are touching the other terminal or a bad shorted speaker. If all external short have been eliminated, a technician would have to fix internal short.
Nov 15, 2010 | Sony STR-DE915
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Hello! I just hooked this receiver up after some time sitting in the closet and it works for less than a minute and then the sound switches to the TV and PROTECTOR flashes across the Reciever screen? I...
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Jan 30, 2010 | Sony STR-DE845 Receiver
I have a new house that had speakers built into the cieling. I bought an onkyo to push all eight speakers. the reciever went into protect mode. i had an old reciever and hooked four speakers to the onkyo...
you can check them with a ohm meter, hook it to the wires that you hook to the reciever and if you get a reading it is good if no reading it is bad wires
Nov 22, 2009 | KEF Audio Cresta 2 Speaker
My stereo keeps saying ''protect''. how can i fix it? ive tried to unplug it for 4 hours and it still dont work
Check the speaker wire connections and make sure that none of them are crossed. Shorted wires will cause the reciever to turn on the protect mode to keep the amplifier from shorting out. Try disconnecting the speaker wires from the reciever. if you turn it on and it still says "protect" then the short is possibly in the reciever itself.
Nov 08, 2009 | Cars & Trucks
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
I lost the installation manual on JHT525.
plug your low input into the subwoofer output of your reciever.that should get the sub working then you have to run speaker wire from your speaker outputs on your reciever into your sub in the top row of inputs then the outputs on the back of sub(the bottom row of speaker hookups go out to your speakers....my email is bsharp76@hotmail.com if you still cant get it i can talk you through it on there or ill give you my instant messenger name is you still have problems good luck,b
Apr 05, 2007 | Jensen JHT525 System
Power Acoustik TS620-2 Amplifier
Check the wiring at the speakers themselves. It's possible that while you were moving the box one of the speaker wires came loose and shorted against the other terminal. A shorted speaker wire or damaged speaker will cause the amplifier to go into protect mode. If you have a digital multimeter with a resistance feature, you can test the resistance between the positive and negative terminals for each speaker.
Feb 26, 2007 | Power Acoustik TS620-2 Car Audio Amplifier
Kenwood KDC-138 FM / AM Receiver Logo
111 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
