Televison & Video Logo
G
Gary Longman Posted on Oct 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The picture was fine when tv was linked to the BT tv kit. Now it's connected to the digitak aerial the picture has a pink/red tinge. How can I correct this? Thanks Gary L
Steve Luck
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 819 Answers
  • Posted on Oct 13, 2015
Steve Luck
Master
Level 3:
Dedicated:
Answers
819
Questions
0
Helped
218665
Points
2252
Hi Gary. Not sure if this will be of any help, but have you tried connecting a DVD player and seeing if that is still colour tinged. It may be possible that your TV may have developed a fault and coincided with changing your aerial and there is in fact nothing wrong with the new aerial. I hope I'm wrong. If you are connecting through a different signal input socket, that may also be faulty or dirty. Basically, until someone can come up with a possible reason and fix, it may be worth ruling out other causes for the problems. Regards, Steve.
1helpful
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
1helpful
My Tristar TV signal booster has a red light illuminated, I think is says 'short' above it. Is the booster working? I have fault on my TV it maybe this. The booster has been working fine up till...
I too have a red "short" light on my Tristar booster. However- I've illiminated the Tristar as I unplugged it and connected my tv directly to the 13amp mains and b) connected the aerial directly to the aerial wall socket which is separately boosted from a distribution amplifier box in the loft. Picture was U/S so the "short" is probably in my cabling in the loft (I've been moving the aerial about lately).Hence I suggest initially to unplug the Tristar and check the fault is not back further up the line ie the cable and booster at top of house. Hope that all makes sense.ps before noticing the red "fault" light, my picture had gone to pot.
3helpful
Pictures taken recently have a pink tinge, eg the sky is pink and skin tones are wrong.
your settings are wrong on the brightness and contrast
some of the power shots set up by using KELVINS as the method of balancing the warmth or coolness of a picture. Others have a setting for OUTSIDE Inside Halogen and fluro If its set on halogen and you are taking pics outside it will have a red tinge.
Fluro a blue tinge...
check the manual for the right selections
please rate my help++++Thanks for using FIXYA
3answers
Phillips 55'' rear projection tv model #55pp970104
That is a convergence problem, it may be because of a faulty defective IC.
Red picture
Only thing I could think of is check your Pscan on your players make sure the correct setting is set for Progessive Scan and the other thing is a common Did you check the cables ??
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Photo-copied Blk & White pictures come out with a pink tinge instead of blk & white.
haven't come across this problem myself, but renew all the ink cartridges, using Epson genuine only and no refills
2answers
Digital pictures have a red/pink tinge on the borders
This is in all probabilty a CCD or processor fault A repair shop jub- unless you have some warranty left Try the Canon Tech support team first though.
3answers
Powershot A70 pictures have pink tinge
When you say produce a pink tinge do you mean on the view screen on the back or through the viewfinder or on prints or an the computer screen? go into more detail if you please
5helpful
5answers
Problems with the picture on my tv. Pink lines across its screen
take the back of the television and atthr back of the screen there is a sucker that sits on the back of t give it a tap and the pink goes away
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
