Question about Tomtom GO 300 GPS Receiver
I need to buy a main circuit board for tom tom 300, need to find a supplier
Philips flat screen TV, model 47PFL5432D/37 46" Problem one: Have to turn on and off several times to get it to come on. Problem two: screen darker on one side and screen flutters/flashes.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 14, 2017 | Philips Televison & Video
Green World/Turbo Air Model GST-40DR. Where can I buy a main circuit board?
Check with a local appliance parts supplier and/or Green World to determine availability and source.
Aug 19, 2015 | Refrigerators
I need Q1 transistor for 135 hobart welder
The transistor is mounted on the main circuit board, you cannot buy the part from Hobart or Miller, they only sell the complete circuit board.
If you can read any part numbers from the transistor you can purchase the part from a electronic parts supplier.
Jul 13, 2014 | Hobart Handler 140 Mig Welder
Tom Tom Go 300 Battery replacement
not a good idea, as it is part of the circuit/antenna and needs good contact to function fully
Jan 03, 2010 | Tomtom GO 300 GPS Receiver
Need to Buy a main system board/controler board for BenQ DV3750
Really Did not find a solution because we already know the problem. i.e the mani/digital board. BenQ will not sell us the part. We are still looking for a supplier.
NEVER NEVER Buy BenQ
Nov 15, 2008 | BenQ DV3750 Television
Just stoped working
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Tomtom GO 300 GPS Receiver
Tom tom 300
If the unit is still under warranty, send it back to Tomtom. Even if the unit is no longer under warranty, complain to Tomtom. There is a problem with the CLA (cigarette lighter adapter). It can cause internal damages to your Tomtom. What happens is that there are three wires in the CLA along with a voltage stepdown circuit board. The wire are +, -, and a signal wire. If the signal wire get disconnect the voltage could spike up to 12vdc. The unit is designed for only 5vdc.
If the unit is out of warranty then try the following website for repairs. They can fix the two chips which usually blows.
http://www.satnav-shop.com/
Jan 26, 2008 | Tomtom GO 300 GPS Receiver
Tom tom go 300 product code lost
Im slightly confused???
what was it you need your product code for?
You brought new maps, that need a product code to install?
Now tomtom say you need to buy new maps to get a new product code?
Dec 10, 2007 | Tomtom GO 300 GPS Receiver
Back to English language
main menu
touch - blue spanner
touch - blue arrow till you find the flags!
select your language
Sep 28, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
370 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
