Question about Technics Audio Players & Recorders
I have a Technics SA-EH600 sound system when I try to turn on either with remote or power button the system diplays goobye and will not function ,this is an intermitent fault
4 Suggested Answers
  • 4234 Answers
SOURCE: help urgently required.....
The click you hear is the power relay. Normally that would be followed by amother click of the speaker relay. In this case, the output section is in protect mode because of a fault detected. This will prevent the speaker relay from turning on the speakers. This amp will require repair. I don't recall your specific model, but if it has discrete transistors, expect a parts cost in the $20 range. If it has a single output amp pac, then the part could be in the $65 range. Add in the local labor rate for the complete repair cost.
Dan
Posted on Apr 02, 2008
  • 4234 Answers
SOURCE: Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Posted on Feb 18, 2009
  • 444 Answers
SOURCE: Looking for a technics sa-eh600 remote
Good luck.Most universal remotes will work with with technics equipment,
Posted on Oct 27, 2012
Technics sc eh600
Check the integrity of your speaker wire, make sure they are 'phased' (-+) properly, also check all other connections, it sounds like the protection ...
Nov 25, 2013 | Audio Players & Recorders
Oct 27, 2012 | Audio Players & Recorders
I have an old Technics SA-GX300 receiver that works fine except that the screen indicates that muting is on (still produces volume but at much lower levels). I lost the remote to the receiver. Is there...
Reliance on the remote instead of walking across the room to touch the unit will not solve anything. On many receivers, Muting is cancelled if the volume knob is turned to a louder level. Try that.
There's a used original remote for $12 delivered on eBay right now.
http://cgi.ebay.com/Technics-RAK-SA301P-Audio-Remote-Tuner-TV-VCR-CD-/230644267386?pt=LH_DefaultDomain_0&hash=item35b378397a
Jul 08, 2011 | Technics SA-DX850 Receiver
Tape deck not working on a technics rs-eh600. Small belt has slipped off, need advice in putting back on.
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Apr 02, 2010 | Technics Audio Players & Recorders
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
Output Power of a Technics SA-DV250 sound system.
100 watts per channel both channels driven into 6ohm. You can download the owners manual at http://www2.panasonic.com/consumer-electronics/support/ (Technics and Panasonic are both made by the same company) Then enter your model #. the specs are on page 23 of the manual.
Feb 25, 2009 | Technics SC-DV290 System
Technics manual sleh600
Technics SL-EH600 is CD changer, which is part of SC-EH600 syste, so download:
SC-EH600 Manual, scroll to pages 18-21 for SL-EH600.
Feb 24, 2009 | Technics SCEH790 CD Shelf System
Technics SA-EH560
Hi! The Technics SA-EH560 dosent work the FM radio tuner. Anybody can help, then please Thanks a lot!
Gabor
Aug 01, 2008 | Technics SC-DV290 System
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Audio Players & Recorders
359 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
