Question about NetGear DG834G Wireless Router
Having major difficulty in connecting to the internet through my wireless router.Working previously but attempted to put security onto setup & now when trying to access the net I get a problem of the net recognising my computer with an error message stating problem with 192 or my server.Any ideas of how I can rectify?
  • 1,272 Answers
Hi, Follow the steps below to configure settings:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the User Name as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'.
6. Set the 'Authentication Type' as automatic.
7. Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Scan for the wireless network on the wireless enabled computers and connect to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 13, 2009
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
Router working fine,but when i try to make it a secure system,even i cant get onto the wifi
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 17, 2010 | Belkin (F5D7230-4) Router (587009)
I am having difficulties connecting
first of all you need to reset your router.
what internet connection do you have like dsl , dailup
do u have static ip for your internet
Jun 16, 2010 | Linksys Wireless-G Broadband Router
Getting my other computer internet wireless
I went through the setup wizard and downloaded the info on my thumbdrive & tried to set up my other computer. I still cant figure outwhy i dont get internet.
May 04, 2010 | Linksys Wireless-G WRT54G Router
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
We just got wireless internet this past year at our house and when my dad set it up he forgot to write down the password which lets you onto the internet. So now we are able to log on through the computer...
to set the wireless settings you need to use a computer that is connected to your router or the computer that is working on your router wirelessly.
access the setup page of your router using IE on the address bar type the ip of your router, by default it is 192.168.1.1, username=admin and password=password, once your on the setuppage go to wireless settings option on the left pane. you will be able to see the wireless security there.
the reason why you dont know the wireless security for the old computers its because once you typed the security key in the computer will remembers it and save it on the system.
Sep 16, 2008 | Intel Computers & Internet
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
D Link DIR 615 and Acer notbook not talking
Run the windows wizard to setup a network connection from the control panel. Be sure you have the security type and code if you have security enabled on the wireless router.
BXH_5
Jun 17, 2008 | D-Link DIR-625 (790069292637) Wireless...
NetGear DG834G Wireless Router Logo
103 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
