Question about HP Photosmart C4280 All-in-One InkJet Printer
It prints from the computer but will not scan. It just comes out black. Also when I use the template to align, the machine says it doesn't recognise it.
    Habit-Forming:
  • 121 Answers
First,if it does show scannes error,the scanner unit is bad,but if it runs through without any picture,replace the scanner lanp and test if problem pesist,replace the scanner unit.
Posted on Jul 13, 2009
  • 152 Answers
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Have changed the black ink in the printer as it was displaying error code 4. It is now displaying error code 5! What does this mean. What should I do?
Error E5.
Cause : The FINE Cartridge may not be installed properly or the Cartridge may not be the compatible with the machine.
Action : Install the appropriate FINE Cartridge. If the lines are misaligned or the resulting output is not satisfactory, carry out the FINE cartridge Alignment.
Replacing A FINE Cartridge.
When replacing a FINE Cartridge, check the model number very carefully.
The machine will not print properly if the wrong FINE Cartridge is used, or installed incorrectly.
Black : PG-40 Black
Color : CL-41 Color
The FINE Cartridge PG-50 Black (High-Yield) and CL-51 Color (High Yield) are also compatible with this machine.
When a FINE Cartridge runs out of ink, replace it using the following steps.
1) Ensure that the machine is turned ON, and then open the Scanning Unit. The FINE Cartridge Holder moves to the left.
Pull the Scanning Unit Support down into place.
2) Remove the empty FINE Cartridge.
a) Push the FINE Cartridge carefully to avoid staining your clothes or the surrounding work area.
b) Remove the FINE Cartridge.
Important : * Handle FINE Cartridges carefullu to avoid staining your clothes or the surrounding work area.
*Discard empty FINE Cartridges according to local laws and disposal regulations.
Caution : Do not touch the transparent film, film cable, ink absorber (sponge part) or any metal parts.
3) Prepare a replacement FINE Cartridge.
Unpack a new FINE Cartridge and remove the Protective Tape.
Important : * Do not reattach the Protective Tape once you have removed it,
* Handle the removed Protective Tape carefully to avoid getting your hands dirty or staining the surrounding work area once you have removed it.
* Once the Protective Tape is removed, do not touch the gold terminals of the FINE Cartridge or its nozzles. The machine may not print out properly if you touch the terminals.
4) Insert the new FINE Cartridge.
Black FINE Cartridge should be installed into the left holder and Color FINE Cartridge should go into the right holder.
a) Insert a new FINE Cartridge on a slight tilt.
b) Push the FINE Cartridge up until it clicks into place.
5) Close the Scanning Unit.
Lift the Scanning Unit slightly and put the Scanning Unit Support back to its original position,
Then close the Scanning Unit.
The FINE Cartridge Holder moves to the right.
Note : IF the straight line is misaligned or the FINE Cartridge position is misaligned, align the FINE Cartridge position.
Important :
* To maintain optimal print quality, we recommend that you use Canon brand FINE Cartridge. Replenishing ink only is also not recommended.
* Replace the FINE Cartridge runs out of ink, replace the FINE Cartridge with a new one immediately. If you replace it with the FINE Cartridge that has previously been removed, the machine may not print properly due to clogged FINE Cartridge nozzles. Furthermore, the Low Ink Warning dialog box which advices when to exchange the FINE Cartridge will be inaccurate.
* To maintain optimal print quality, use up all the ink in the FINE Cartridge within six months of its first use. (We recommend that you note the date that the FINE Cartridge was installed in the machine.)
* Color ink consumption may occur even when black-and- white or gray-scale printing specified.
Color ink is consumed during Cartridge cleaning, which is necessary to maintain the machine's capabilities.
Aligning The FINE Cartridge
If ruled lines are misaligned or a printout is unsatisfactory, FINE Cartridge Alignment is required,
* Aligning the FINE Cartridge
1) Press [Maintainance] repeatedly until <P> appears.
2) Press [Black] or [Color].
The machine prints the head alignment sheet.
3) Beginning from Column A on the printout, enter checkmarks in the patterns that have the most solid image.
4) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
5) Press [Maintainance] repeatedly until <U> appears.
6) Press [Black] or [Color].
The machine scans the pattern and aligns the FINE Cartridge automatically.
Note : If you select <L> in step 1, the machine prints the current FINE Cartridge Alignment setting.
Hope this helps.
Please rate my response
Thanks.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How to configure printhead alignment
Hi there, Aligning the Print Head
If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
Steps for Aligning the Print Head.
1) Press [Menu] repeatedly until [Maintenance] appears.
2) Press [Maintenance] repeatedly until <P> appears.
3) Press [Black] or [Color].
The machine print the head alignment sheet.
4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
5) Load the checked sheet on the Platen Glass.
6) Press [Maintenance] repeatedly until <U> appears,
7) Press [Black] or [Color].
The machine scans the pattern and aligns the Print Head automatically.
Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
Hope this help.
Have a good day.
Dec 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Print alignment failed / have tried to rectify several times
It seems like it may be a hardware problem, but the best bet for you would be to reinstall the printer drivers. It should fix it,
Jul 27, 2009 | HP Photosmart C7180 All-In-One InkJet...
Changed black cartridge. Machine works fine, but
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Alignment of cartridges
Apr 17, 2009 | Lexmark All-in-One Printer with PictBridge
Test and scanning the alignment page
we have a link on how to fix your own printer through this link(check for search box further down page)
Mar 08, 2008 | Lexmark X2470 All-In-One InkJet Printer
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP Photosmart C4280 All-in-One InkJet Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
